Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 62
    Jan 2009
    #41
    sorry about your accident. grabe naman sunod sunod pa.
    i guess paayos mode muna kayo. good luck.
    Sep 2010
    #42
    whaaaaaaa... sayang naman ang pinaghirapan.....:crying::crying::crying:
    #43
    its much better to use the ipf j low beam xxx than buy an expensive hid which gives off a white light not good for rainy weather or fog.a hid low cost bulb does not last longer and the price is absurd!!!!!
    Jan 2003
    #44
    Ouch!!! sandwich!!!
    magkano kuha nyo sa delica headlites? balak ko din gawin driving/fog lights sa vitara ko.
    wala kasing lumabas na clear plastic lens ang vitara
    #45
    Quote Originally Posted by johnbarry View Post
    both HIDs are 4300K. mahigit isang taon na yung generic HID ko at wala pa nasisira. Natsambahan siguro.
    #46
    Quote Originally Posted by impulzz View Post
    Ouch!!! sandwich!!!
    Sir, sorry for the late reply.
    One pair ng delica headlights, if I may recall, is P1,800. Sa banawe ko nabili.
    #47
    idol!!!!!! astig ang retro niyo sir! pero kainis yung bumangga , a work of art nasira ng ganun ganun lang.
    #48
    Quote Originally Posted by xenonoptics View Post
    sir.. thanks. i plan to re-install my bi-xenon projectors kaya lang eh no free time. surely will post update once it's finished.
    Nov 2007
    #49
    wow,thanks for sharing sir!magkano lahat nagastos nyo
    #50
    Quote Originally Posted by john5 View Post
    para dun sa HID fogs:
    Delica HL - 1.8K
    China HID H3 - 3.5K ( price nung 2009. now mas mura pa )
    para sa Head Light
    used Mercedes Benz Bi-xenon projectors - 12K o 15K yata.
    aftermarket HL H4 wire harness - P900
    for the head light, if you are tight on budget, i would suggest you get the bolt on HID projectors. someone is selling it for around 6.3K if i may recall it right.
    HTH
    #51
    [SIZE="3"]Sir,
    Tanong ko lang kung paano nyo ginawang clear yung lens nyo? Niliha nyo lang ba hanggang maging clear?
    TIA...
    [/SIZE]
    #52
    Quote Originally Posted by erick_214 View Post
    [SIZE="3"]Sir,
    TIA...
    [/SIZE]
    yung unang gawa ko sa lens eh niliha lang para maging clear. matagal pag mano-mano. umpisa ako sa 200 then 400 then 1200 then 1600 then 2500
    pero meron din ako ginawa na pinalitan ko na lang ng clear polycarbonate sheet yung harapan -mas maganda yung light output.
    HTH
    #53
    Finally, i have re-installed the bi-xenon HID on my headlights.
    Also added a halogen high beam inside the headlights. good for flashing on daylight as my bi-xenon HID will not light up or flash. this is wired in such a way that the bi-xenon HID can only be turned ON when my park lights are ON.
    sorry for the crappy pics. lo-end cam phone kasi gamit ko.
    Jul 2003
    #54
    Quote Originally Posted by rmpmla View Post
    Ayus bro galing! musta na pala water injection natin?
    #55
    Quote Originally Posted by nap123 View Post
    Thanks Nap. Working pa rin yung water injection although i encountered malfunction of the pump a month ago.
    Ito rin siguro yung naging problema nung nag pa-install na hindi tumagal yung pump. found out that the limit swtich for over pressure is broken.
    How about your WA injection set up? gamit mo pa rin sir yung electronic pressure switch/gauge? still OK?
    Jul 2003
    #56
    Ayus parin bro kasi sa loob ng car ko nakalagay kaya hindi naiinitan ang pump ko. Plano ko mag dual nozzle, i bought pala sa devils own ng d02, nozzle adapter at at yung pang dual.papalitan ko yung sa coolingmist nozzle at better lagyan ko ng nozzle adapter din para madaling tangalin mahal ngalan din biruin mo 2.8K din inabot ko peso parating na etong March. Oo bro ayus parin yung electronic switch meron pa ako dito hehehe.
    #57
    bibili sana ako ng electronic switch dun sa surplusan as spare kaya lang eh hindi ko na makita yung pinaglagyan na drum. natabunan na kasi ng ibang pyesa.
    bro, sent you PM.
    Mods sorry for the OT
    #58
    update lang po.
    FX-R projector,55w HID kit, new clear lens ( molded using an oven toaster )
    for those inquiring about the clear lens. Pinalitan ko na yung dati na Polycarbonate hindi kasi ganun ka clear. Ginamit ko na ay Acrylic at molded according dun sa curve ng original na lens.
    Sorry, wala na detailed steps and photo pero madali lang ito especially sa mga old style lens na hindi masyado ma-curve.
    #59
    update lang po.
    Sir magkano score mo ng 55w hid and where?
    #60
    YGPM bro. ;)
Another DIY HID projector headlight. Caution-modem burner
