Results 11 to 20 of 44
February 18th, 2013 10:07 AM #11
I would think nagbabakasakali lang si TS na may easy upgrade na makakadagdag sa output ng HL niya to offset the new tint. Not that he needs more light, but a little more light generated through a quick (though responsible) fix would be welcome.
Anyhow, if that tint can't go any lighter, than for max output go to garyq, otherwise there's little that a halogen bulb upgrade can do.
February 18th, 2013 10:21 AM #12
February 18th, 2013 10:24 AM #13
ito! tama sir, haha! salamat! di ko kasi maipaliwanag :D sorry. and tama, responsible way without irritating other drivers on the road, btw since 100/80 watts ilaw ko, medyo naka aim pababa so di nakakasilaw as i havent experienced getting the pitik from oncoming drivers, and i tried to align it higher and ok naman pero inaalala ko baka makasilaw sa iba.
- Apr 2009
- 429
February 18th, 2013 11:17 AM #14IMHO, putting heavy tint on a windshield is one irresponsible way a motorist can be. Why, because your blindspot is magnified significantly. It also eliminates the peripheral light thrown by your headlight such that only the central beam is seen but reduced significantly nevertheless. Yes, putting a dark tint on your windshield is a personal choice as the car is yours but do note that the road is not yours and used by everyone else
BANNED BANNED BANNED
- Jul 2003
- 2,267
February 18th, 2013 11:26 AM #15
- Jul 2011
- 1,711
February 18th, 2013 11:36 AM #16
- Dec 2002
- 2,335
February 18th, 2013 12:54 PM #17biggest reduction ng good lighting output is dark tint. Even a medium dark tint will affect considerably the output of a stock halogen bulb.
If you want the cheapest solution, go for a lighter tint.
Can I request tsikoteers to make objective comments kahit meron mga seemingly uninformed comments?? Let's keep our board interesting to look at and full of objectivity. Thanks guys!
February 18th, 2013 05:34 PM #19
I've gone as dark as Panther 5 a long time ago. No HID option then. No fun except for the fact that it was summer then, but once the rains came, I eventually went with Panther 20 (dark smoke). Ever since it was either dark smoke or dark magic -- so that's darkest at 20 for the dark smoke (not sure what dark magic is nowadays, it used to be about 20, too).
Anyhow, my point here is if you're set and happy with your tint and won't go lighter, that's your personal choice. But unless you are open to going for a retrofit or bolt on projector with good performance, don't waste your money on getting a higher powered halogen bulb. It won't appear to be that much brighter. There's only so much halogens on multireflectors can do. Sayang pera.
February 18th, 2013 08:24 PM #20
heavy na ba yung hp supreme 22? if that's the case, i did it kasi napakainit talaga and for security reasons na i will keep for my self. and, i plan to go to a lighter shade once na lumamig lamig ng kaunti, thanks sir!
as far as i can remember, i just wanted an improvement, not to the point na makakasilaw ako, just an improvement :D
yup sir, salamat po, mag lighter shade po ako pag lamig lamig and baka mag pa retro ako ( i have been itching to have my hl's done kay sir gary di lang ako makaipon pa )
and its right above an electric motor....
BYD Philippines
