Results 21 to 26 of 26
October 17th, 2006 06:27 PM #22
Yung quickest na remedy is to reset the ECU or irereset sa diagnostic box (parang may pina-short but hindi ko nakita kuing anong slots ang pinashort). Yung una kasi nangyari sakin yung AIRBAG ko nagbliblink. Tapos nung pinataas ang kotse at pinaandar, bigla naman nagblilink ang ABS ko. Code 5-3 or 5-6 or 5-9 yata... pero wala ito sa service manuals. Yun pala dapat hindi nakataas ang car kasi di yata madedetect ang ABS sensor ang brakes or something. Baka ganun din ang nangyari sayo since may problem ang front suspension mo.
Wala naman problem kung disabled ang ABS. Ang basic design ng lahat ng ABS equipped vehicles is kung masira man ito, it's like having conventional brakes as you said.
Try Kia Pasay. Doon ako nagpapatingin ng problems ng baby ko.
October 18th, 2006 04:16 PM #23
sori,but not hold true to some abs system like the bendix 9 and 10 abs pag nagfail abs fail din ang base brake system
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 18th, 2006 08:55 PM #25
July 25th, 2008 01:59 AM #26
nice info. very helpful talaga si sir speedy! may wi fi pa! XD sayang sira na yung ps2
high idle RPM at engine start
