Results 11 to 20 of 26
October 11th, 2006 11:14 AM #11
Madalas nga yung wheel sensors ang may fault. Exposed kasi sa environment.
October 11th, 2006 11:17 AM #12
thanks guys.
baka nga ung sensor... may problem din kasi ung front suspension (some squeaking sound) after having it repaired.
October 11th, 2006 06:13 PM #13
Have you tried to activate the ABS with hard braking? Tignan mo muna kung affected. If it's over-active, better have it fixed... if it's out... oks lang yun...
October 11th, 2006 08:02 PM #14
e pano kung hindi nag-off yung ABS light, pero nung nirestart ko nag-off din after. minsan lang ito mangyari, at kasabay niyang umiilaw ang hand brake light. ano kaya ang problema kapag ganun?
October 11th, 2006 08:29 PM #15
problema ko rin ngayon yan..hehehe
pansin ko medyo malalim na rin yung brake disc rotor ..pero, i-try ko rin palinis muna (baklas) yung caliper..baka makatipid pa ng konti..hehehe
October 11th, 2006 08:46 PM #16
Had a friend who bought a LC100, one time the handbrake light turned on and wont go off. pina check sa casa and they also found out that the abs warning light has no bulb in it. when they put in a new bulb it was lighting up, sira pala ABS. if the warning light is on its just same old vehicle without ABS ang function ng brakes.
October 11th, 2006 11:04 PM #17
Importante diyan is road test niyo. Yung samin ginamitan ng scan tool and road test to determine what was at fault.
So now, we just drive it like it has conventional brakes.
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 17th, 2006 04:40 PM #20
same problem with ABS light of my then 316i, though mukhang di naman yata ABS pump(ang mahal nito)...madumi lang sensor. after a few times na pabalik-balik sa shop to have the deym sensor cleaned/fixed, i decided to just have the abs light 'disconnected'. kakairita kasi pag nakailaw
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
