Results 1 to 10 of 49
- Dec 2007
- 28
August 4th, 2008 01:23 PM #1To those of you out there who have tried Wonder Lube, could you please confirm if it really works as advertised. Is it true that it saves you up to 25% on fuel, prolongs oil change, reduces toxic emissions, restores power, prolongs engine life, etc.?
August 4th, 2008 01:30 PM #2
August 4th, 2008 02:33 PM #4
why spend P150-P300 on a fuel additive that promises to extend mileage when u can use that money to buy fuel instead?
Fuel additive (cost P150-P300) = extend mileage (di pa sure yan)
Additional 2 to 4 liters fuel (P120-P240) = extend mileage guaranteed
August 4th, 2008 10:32 PM #5
The reason why it is called 'Wonder Lube' is because people 'wonder' whether it really works or not
- Jul 2008
- 66
August 5th, 2008 07:46 AM #7
August 5th, 2008 08:48 AM #8
ay mali!
i was thinking of that local fuel additive that's made from plant oils
- Dec 2007
- 28
August 8th, 2008 08:04 AM #9Guys, correct me if I’m wrong but I think savings computation should be done this way.
- original duration of oil change = 3000 km
- oil change duration after using wonderlube = let’s say it increased to 4000 km
- Let’s say, changing oil incl labor costs P1,200
- Savings = (1200/3000 – 1200/4000) = P0.10/km or P400 for every 4000 km
Add fuel savings of 25%
- Let’s say, originally fuel consumption was 8km/li or P7.50/km
- 25% savings would be P1.875/km or P7,500 for every 4000 km
Thus, gross savings for every 4000 km would be 7,500 + 400 = P7,900
Deduct cost of wonderlube = say P800 (I’m not sure how much) per oil change then we get a net savings of P7,100 between oil changes or equivalent to P1.775/km.
Add the extra benefits of prolonging engine life, increased engine power, minimized emission of harmful gases and smoke, smoother engine, etc.
It would be great to use Wonder Lube but only if their claims are true, of course.
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 8th, 2008 08:25 AM #10I have not tried wonder lube, but I have doubts about its ability to save fuel. For 1 thing, AFAIK, there have been no independent lab test that have confirmed its claims. 2. The US EPA have tested a lot of so called additives and have not found 1 to work. Some of the brands that I recall are, Duralube, Motor Up, Z Max etc.... Just google it. If you really want to try, its your money.
To save fuel, use API rated energy conserving oils. This will really save you gas. Brands that are easy to find in the Philippines are Caltex Havoline Energy and Royal Purple. I have seen a few others at True Value but dont remember the brand names. Typical viscosity for this type of oils are 5w30 and 10w30.
the GI sheet missed you? you did not run out of fuel, and the aircon was good? you got home in...
Traffic!
