Results 1 to 10 of 20
- Jun 2008
- 11
June 17th, 2008 03:26 PM #1Does driving in really low rpm help in reducing the consumption of gasoline? I've been driving like this for sometime now, mostly reving it at less than 2000rpm. I even run 40kph already at 4th gear. Im driving an 11-year old civic and am afraid that what im doing will cause damage to the engine/transmission/etc. At, kunyari maluwag yung road, tipong bumubwelo ako ng speed, then drop the gear to neutral, para hindi laging nakatapak sa silinyador.
June 17th, 2008 03:43 PM #2
If the car's having a hard time, you're hurting the engine.
Yes, driving at low rpms will help save gas, but if you're "lugging" the engine, it'll lead to accelerated wear and tear.
June 17th, 2008 04:17 PM #3
agree.. pero if your coasting on the highway, better FC if you're close to "engine idle speed" thats the secret. now gearing will determine your cruising speed.
most gas cars * 5th gear * 1500-2000 rpm thats 60-80 kmh
focus diesel coasts * 90kph * 1800-2000 rpm
kung country road or city driving, anticipation is the key factor in order to get a good FC
June 17th, 2008 04:30 PM #4
June 17th, 2008 04:46 PM #5
I think that the best way is to rev moderately meaning not too low or excessively high like doing jack rabbit starts.
June 17th, 2008 04:49 PM #6
It's all about gearing....
If your car is geared for economy (as in a manual trans) then the 5th or 6th gear would drop the engine speed down close to idle when cruising. But when you're in city driving you'll need a smaller gear ratio so your engine can transfer its power easily to the rear wheels. Otherwise, as Niky said you'll be lugging the engine, which is both mechanically inefficient (wastes fuel) and wears the parts more than it should.
Just get a feel for it, usually it's at the point when minimal accelerator input leads to "just enough" acceleration. If the same accelerator input makes it feel it needs more power, then you're lugging the engine. Same with the opposite, but you're racing the engine that time. So find the sweet spot and use that combination as soon and as often as possible, to save on fuel. Gentle acceleration lang ha, when I say as soon as possible, baka naman you "race" to that speed then switch to cruise mode. Sayang lang tinipid mo if you race to that speed...
Hope that clears it up a bit
- Jan 2008
- 4,726
June 17th, 2008 05:05 PM #7at 5th gear maintain speed of 60kph to 80kph max shifting below 2000rpm (1500 - 1800 rpm) is also good especially if you are not hauling cargo or carrying peeps.. sure you will have lower FC.. eventhough you maintain speed of 100kph - 120kph bottomline is still you will get to your destination no matter how fast you drive... it is because at the end of the road, all of you will be caught at the same TRAFFIC...
June 17th, 2008 05:29 PM #8
Contrary to popular belief... "hyper milers" do speed averaging and get better fuel mileage than steady speed. Example, if you want to go an average of 70kph, you speed up to 80kph then go into neutral and coast your car until it reaches 50/55kph then slowly speed up again to 80kph.
June 18th, 2008 01:06 AM #9
Avoid gunning your engine and anticipate braking on city driving. This principle also apply on highway driving.
June 18th, 2008 05:26 AM #10
Went to Angeles City (Friendship H-way Cut-cut) and Clark Airbase Pampanga last Monday with 700 pesos of gas (Caltex Gold). With an average speed of 80 to 90 kph (1500 - 2000 rpm) at NLEX plus the city driving, I was able to run a total of 205 kms approximately.
Low-rev driving really improves FC.
Wen I sold my car, I politely rushed the buyer to process the Deed of Sale. In my mind, may...
LTO car registration and late registration fees
