Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 101 to 120 of 184
    metro east ☁☁☁☠☠☠
    Jan 2018
    #102
    Phoenix Premium 98 sulit mura pa.
    #103
    Quote Originally Posted by mbt View Post
    unleaded lahat ng fuels ngayon... kahit blaze/velocity... and shell super and vortex gold...
    Yes, all fuels are now unleaded!
    "Unleaded fuels carry a RON (Research Octane Number) rating. Put simply, RON determines petrol's 'anti-knock' quality or resistance to pre-ignition; or if you want to put in another way, the Octane Number denotes its resistance to detonation."Aug 23, 2008
    The Real McCoey on RON - Research Octane Number
    Car News, Reviews & Guide - Buy, Sell New & Used Cars | Drive › the...
    Quote Originally Posted by Maricar View Post
    Racing fuel kapag nagra-race kami sa track ng b/f. Expensive kasi kung yun ang gagamitin for daily driving.
    Sent from my GT-I9505 using Tapatalk
    Feb 2018
    #104
    Unioil 91 because of the S&R discount
    #105
    from Total to Phoenix mas matipid gas ng phoenix.
    Mar 2018
    #106
    100ron / blaze. madami akong pera eh
    Jul 2015
    #107
    Quote Originally Posted by NoelCruzFlores View Post
    for what vehicle sir?
    Sep 2006
    #108
    91ron shell and petron.
    #109
    is there a real performance difference?
    Oct 2003
    #110
    Dapat diyan blind testing para scientific conclusion.
    Jul 2016
    #111
    Mag unleaded yung pinaka mura na lang kayo. Kasi sa gas station pag nag drain na sila.ng laman ng tanker lahat ma drain nila ilalagay nila yan Sa pinaka mahal product. Hindi ko sinasabi lahat ganyan ginagawa pero karamihan ganyan ang procedure.
    Sent from my vivo 1606 using Tapatalk
    #112
    did they say why they do it?
    For everyday use. Kung ano yun pinaka mura, “unleaded” which is naging generic term na ng cheapest gasoline sa gas station.
    Pag nag out of town and higher chance na meron mahahabang long stretches na mabilis ang takbo. That’s the time na nagpapakarga ako nun highest RON rating na available sa gas station.
    #114
    i fill up before goin' on a long trip.
    ayaw kong magpa-gaso sa province.
    i don't trust the quality of the gas stations there.
    #115
    Only if your engine requires it. However, if you’re driving a low performance subcompact or compact with a small output engine, I guess you are better off with the 91RON.
    My turbo rides requires 95RON minimum so I use XCS (fleet card so it’s free) or SeaOil Xtreme97 (2 pesos cheaper).
    Mar 2013
    #116
    Blaze has actually less power than 91 octane because it is less dense BUT it is needed by high compression high power engines because the lower density prevents premature fuel detonation in the cylinders. High compression engines develop more power but at the risk of pre spark detonation if fuel mix is too rich. Using Blaze leans out the mixture a bit.
    Engine ECUs are smart enough to detect engine knock due to fuel type and advance or retard the spark timing as needed. But you will lose power.
    Sent from my SM-N950F using Tapatalk Pro
    #117
    Ayan oh, sabi ni EQ. If you don’t have a high compression engine that requires high octane fuel, there will be no gains using Blaze100.
    Mar 2013
    #118
    Correct bro. In fact they may end up losing power.
    #119
    Is the Forester's fb20 a high compression engine?
    Sent from my SM-T705 using Tapatalk
    #120
    The FB20B is not considered high compression, usual 10:1. The newer FB20D on the new XV/Impreza has a higher compression ratio but still not higher than the FA20 (NA for BRZ and turbo for WRX/FXT), around 12.5-13:10.
    Mazda’s SkyActiv gas engines have higher compression ratio, around 13-14:10.
what gasoline do you use.
