Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
    #41
    noteworthy,
    abrupt accelerations that spew out black smoke is not caused by the turbo. it is by the unburnt fuel since you accelerated it abruptly too. for the fuel to completely burn, acceleration should be done slowly and gradually. this after we did a test with a german instructor at TESDA.
    with this action, it also does damage to your turbo's shaft and bearings.
    Doc Diesel
    Jan 2003
    #42
    Thanks for the info Doc!
    Feb 2004
    #43
    so dapat pala gradual ang acceleration/ suave ang hatak para di masyado agrabyado ang engine and turbo. cool, ganyan naman talaga ako magdrive.... on most ocassions
    doc diesel, drop ko yung pajero sa Betan Davao bukas ng umaga
    andy
    Jan 2003
    #44
    I might drop by by next month for cleaning.
    Jan 2003
    #45
    question lang po mga peeps... about sa abrupt stepping sa gas pedals... alam ko masama yun di ba? kakabwisit lang yun nag-eemission test... tama ba yun bigla sagad yun silinyador? pwede mo ba batukan yun nagtetest pag ganun? nang-gagago kasi eh... wawasakin makina mo... hehehehe..
    #46
    nung nagpa-emission test ako last year
    natanggal belt ng power steering ko..
    Jan 2003
    #47
    alam ko may appropriate procedure yan. I'll try to find the manual. :D
    Jan 2004
    #48
    naku, buti pala nabanggit nyo. ndagdagan na naman ang knowledge ko. i used to be "leadfoot" dahil dati gas fed ang madalas kong ginagamit. now i know. wala ba tayong mga book of tips on how to take care of our diesel engines aside from the owner's manual? kasi hindi reliable ang owners' manual, kulang ang mga info. thanks!
    Feb 2006
    #49
    how will I know if the turbo in a 4d56 engine work? I rarely accelerate my tacho to 2000 rpm. I usually drive 1500 to 1800 rpm * 50-70kph on hiways. I still haven't feel that kick in the engine or heard the "whistling sound" when I go above 2,000 rpm.
    Need your info on this. Thanks in advance!
    Mar 2003
    #50
    Sir, kung minsan talaga hardly felt ang pag kick in the turbo...but you'll know your turbo has had it when your rig starts pulling like a gutless pig. =) some mechanic even told me that you can really feel it kapag hirap na ang engine mo (just don't know to which extent)
    too much white smoke can also be a culprit...
    if you really want to see it...just remove the air hose from your intake...you should see your turbo/impeller at work and spinning really fast.
    #51
    install a boost guage, that way you will know if the turbo is boosting or not.
    Mar 2003
    #52
    *ARB - how much does a boost guage usually cost? Would you recommend installing one for stock setups or its more for those who do or did modifications? =)
    Jan 2004
    #53
    Quote Originally Posted by BeetOls
    tama. medyo mahirap pigilan ang sasakyan na may turbo lalo kapag sumisipa na yung turbo. it takes time pero grabe talaga.
    Feb 2006
    #54
    Thanks for the replies BeetOls and ARB. I drove above 2000 rpm a while ago and still there's no kick. Maybe the turbo isn't working..Is it the diesel fuel I'm using?
    Here's the complete story. I always used regular diesel before and as I remembered the kick was there, even at 40kph only. But because of the rising price of diesel fuel, I chose to use 1% premixed biodiesel it is a peso or more cheaper than regular diesel. Since then I have not felt the turbo. I don't know if it has more power or an increase in mileage. And also want to ask if it's OK to shut the diesel engine without reving up just like in gasoline engines?
    Need your opinion on this. Thanks again in advance!
    Mar 2003
    #55
    sir,
    revving up before shutting your TD engine is a no-no. When coming from long drives, you need to at least leave the engine idle for about 3-5mins before turning it off. that should say it in the manual. =)
    about the turbo...maybe your just feeling the effect of biodiesel that the engine was efficiently pulling up even before the turbo kicked in(hehehe).
    i was told that kapag sira na ang turbo mo...sobrang hihina daw talaga ang hatak nyan to such a noticeable extent because the engine has been preconfigured with it.
    Jan 2004
    #56
    baliktad yata ang effect nang biodiesel sa yo? suppose to be mas malakas ang hatak pag biodiesel e.
    ok lang kahit di i-rev ang makina mo basta nakapag cool down ka na. i.e. after nang highway driving or high speed driving, normal range lang ang rpm for 5-10 minutes. after nun pwede na patayin.
    #57
    Pwede ba pakabitan ng turbo yung manual Isuzu Xwind XUVI ko?? kung pwede magkano? Hehehe hanggang 110kmh lang kasi yun mejo binabastos ng mga ibang sasakyan.
    May 2008
    #58
    Quote Originally Posted by arkitek2 View Post
    Hi, Arkitek2!
    I just stumbled across your post and I wonder if your questions have been answered already. Anyway, here is what I can say:
    The biodiesel mix available here is supposed to be for environmental purposes but from my personal experience, m turbo diesel powered Fuego runs more efficiently and thus I have more felt power and better economy. Fuel consumption is relative to one's driving habits and therefore it is difficult to peg an answer but with better efficiency comes improved power and economy.
    The kick you are looking for is not really felt as much with today's smaller, more efficient transitioning turbochargers but the difference in pull you experienced is probably due to engine wear and tear. After a few full tanks of our biodiesel, you can feel the difference after the cleaners/detergents of the biodiesel (depending on which brand-I use Sea Oil) have done their part. I personally have noted the following changes: decrease in smoke, quieter running engine, not much if not no pumping of the fuel feed pump, smoother power, improved fuel economy.
    As regards the "kick", have you noticed any decrease in power or increased black smoke? You may want to have a tune up (including the replacement of all filters). If nothing improves after that, you may want to have your turbocharger inspected also by competent turbocharger technicians for possible "coking". Gunning (revving) the engine is a no-no for any engine, be it gasoline or diesel fed. Now this is especially true for turbocharged engines. What we are pertaining to here is friction (wear) to the engine when oil does not run through it. This happens when you first start the engine (especially in the mornings) and when you shut the engine. So you want to avoid this. Turbochargers (especially those that are oil cooled/lubricated) need oil for their bearings in order to spin. If you rev or gun the engine before shutting down, the turbo remains spinning even after the engine is shut. Without oil to lubricate the bearings, you get wear and the hot oil going through every nook and cranny of the engine and turbo hardens (this is called coking). And this causes the early demise of you turbo. This is why we have turbo timers to help cool the oil and keep lubrication while the turbo spins down.
    I hope I was able to answer your questions.
    Cheers!
turbo diesel...
