Results 1 to 10 of 58
- Nov 2002
- 29
January 12th, 2004 12:18 PM #1tanong lang po sa mga diesel experts: Mas matipid ba ang isang diesel engine kapag turbo ito or mas malakas lang ang output ng makina? or both? Example ay yung 4d56. May turbo at di turbo. Salamat po.;)
January 12th, 2004 12:24 PM #2
Definitely mas malakas ang Turbodiesel compared to its equivalent NA counterpart. IM not sure lang kung ano epekto sa consumo. If i were to guess, i'd say mas malakas din sa krudo kapag may turbo.
- 10,620
January 12th, 2004 12:25 PM #3ese,
from my experience i used to drive a mitsubishi L200 4D56 normally aspirated and now im driving a mitsubishi Strada 4x4
mas malakas di hamak ang may turbo
sa 4x2 nakaka 11-13kms/liter ako
ngayon nakaka 9-11 ako sa strada ko
pero sulit naman sa power and hp
- Nov 2002
- 29
January 12th, 2004 03:02 PM #4kimpoy, di kaya mas malakas ang consumption ng crudo ng strada mo over the L200 kasi 4x4 ito at mas mabigat? Ganun pa man, is it safe to say that a turbo diesel engine consumes more fuel than a non-turbo? thanks...
January 12th, 2004 03:55 PM #5
Turbo added engines infact place more air into the combustion chamber. I have known for the fact that air/fuel ratio should not be altered to maintain steady combustion. Perceptions could be true that turbo equipped engines need for more fuel than normal aspirated units.
Consumption is a subjective topic to tackle, every driver and vehicle varies from one another.
January 12th, 2004 04:17 PM #6
Halos pareho lang naman ang consumo nila. Tama ang figures ni kim, the two will meet at some point.
If you don't drive the turbo engine hard, it will behave and consume like a non-turbo. But when you call in the horses, medyo mas malakas na ang consumption. Pero at least you know the power is there when you need it.
January 12th, 2004 05:54 PM #7Originally posted by ese
- 98
January 29th, 2004 01:18 AM #929Jan2004 (UTC +8)
If your vehicle is always under heavy load, and thus you notice that you emit a lot of black smoke, mas mabuti malamang na mag turbo ka.
Black smoke means unburnt fuel. Unburnt fuel is wasted energy. To burn the excess diesel fuel, you need more air. Turbo (and much better with intercooler) delivers a lot more air for the engine...
January 29th, 2004 07:44 PM #10Originally posted by kimpOy
ese,
high idle RPM at engine start
