Results 41 to 50 of 54
June 6th, 2007 11:01 AM #41
ako rin bumagsak ang mileage ko by as much as 1km/L. dati around 9 to 9.5 km/L (normal 25%highway, 75% city), ngayon nasa 8.5km/L na lang.
around 40L pinapa-gas ko lagi. so that's around 40kms lost. (tama ba analysis ko?)
ano magandang gas ang ipalit sa xcs? yung mura lang sana and 95ron na malakas ang hatak
Zombie
- Aug 2006
- 728
June 6th, 2007 08:38 PM #42would anyone believe me that all efi engines now can tolerate up to 20% ethanol blend without doing any modifications.
but 10% really is safe.
> some people experience sluggish performance because the ethanol in the blend dissolves the impurities sticking on your lines and, also blocks it. < only my opinion
that's why i laugh everytime i see the flex fuel vehicle ford is advertising here in manila.
ethanol is bad for carbs.
June 7th, 2007 07:59 AM #43
Tsikot Member Rank 3
- Oct 2006
- 1,069
June 7th, 2007 08:09 AM #44
Zombie
- Aug 2006
- 728
June 7th, 2007 02:30 PM #45extensive modifications sir, on your fuel lines to your inlet port gaskets, to be ethanol compatible, and then you have to tweak the carb itself. i'm not a carb expert though, so i can't give you details.
for efi engines:
if you want to run your vehicle in more than 10% ethanol blend for a long period you replace the fuel lines, tank, pump, pressure regulator, to be alcohol compatible, or else you'd get leaks all over the place.
and you need to tune your ecu, in a dyno. ethanol has lower energy per mass unit, but it has high octane level.
- Jun 2007
- 16
- Jun 2007
- 16
June 10th, 2007 04:06 PM #49
on a whim, i tried it. here's my initial impressions.
in fairness, maganda ang acceleration, parang magaang dalhin, madulas ang feeling. maganda din ang sunog ng sparkplug.
downside is may konting tope lang sometimes.
June 12th, 2007 09:37 AM #50
filled-up my tank with the new petron xcs last week. and yes, my consumption increased.
with shell/caltex, 30 liters go at 300 kms which is 10 kms/liter.
with xcs, 30 liters only went as far as 220 kms or 7.33 kms/liter.
medyo malaki ang nawala.
high idle RPM at engine start
