Results 11 to 17 of 17
November 5th, 2012 09:57 AM #11
On the other hand, you can also get slightly better response by advancing the timing on the car from the stock setting and using higher octane fuel. Thus, is it safe to say that it's not the fuel per se that's responsible for the power but rather the adjustments the engine makes as a result of the type of fuel used?
November 5th, 2012 10:16 AM #13
Most cars can handle gasoline that's slightly worse than they're programmed for, but sluggish performance and poor economy are a real possibility.
Even worse, I was talking to a fuel engineer, and in his opinion, certain companies had knock sensors and learning algorithms that really can't deal with poor fuel. Which explains the widespread complaints of knock you might see elsewhere in this forum.
This is to say, the ECU can deal with low octane, but only up to a point before it enters a nasty feedback loop and can't pull enough timing to cope. This is similar to the problem wherein some ECUs can't cope with that tiny extra bit of air from the Khaos Super Turbo Charger air-bleed device.
And then there's still the problem with varnishing and contamination. Certain high-end brands which use gasoline direct injection get a lot of customers in the shop who need their fuel systems purged and clean. because they don't cycle the E10 in their tanks often enough. Hell, I lost one fuel pump to E10 contamination myself. (rubber disintegrated completely, because I didn't cycle the fuel in the tank as I was on LPG more often)Last edited by niky; November 5th, 2012 at 10:21 AM.
- Jun 2011
- 48
November 7th, 2012 01:11 AM #14Fact 1 - octane number is an indication of the ability of the gasoline to prevent knocking of the engine. The higher the octane the better the ability of the gasoline to prevent knocking. Generally, higher compression ratio engines have a higher minimum octane requirement. But in the Philippines, majority of the cars have compression that is satisfied by a minimum of 91 Research Octane Number.
Fact 2 - your car's manual states the minimum octane number that your car can take. If your manual says minimum of 91 Research Octane Number (RON), then you should use a gasoline with an RON not lower than 91, or else it will knock. You may however use higher RON without the engine knocking.
Fact 3 - present day computer controlled engines operate such that the computer always automatically and instantaneously advances the engine's spark timing up to the point of slight knocking. So if you use a higher RON like 95, the computer automatically advances the timing some more, up to the point where there is very slight pinging and this advance will give more power. If however you have a gasoline with a lower RON, say 92, the computer retards the timing appropriately thus resulting to lower power.
Fact 4 - it is true that another octane rating is the Motor Octane Number (MON), but here in the Philippines, we use RON in our gasoline labels and in the car manual. The important thing is that the basis of comparison is consistent - meaning RON in the manual compared with RON in the gasoline label. If your car came with a MON gasoline specs, then you should find a way to convert the MON into the equivalent RON. By the way, the MON testing is done under a more stringent testing condition, and this used more often in testing aviation gasoline (Avgas)
Fact 5 - in the older engines with carburators, the advance timing is manually set everytime we use another octane number in order to take advantage of the additional power afforded by higher RON. If we do not manually advance the timing, the higher octane has no benefit at all.
I hope this gives some enlightenment to our Tsikoters.
November 7th, 2012 12:32 PM #15
- Jul 2012
- 81
December 11th, 2012 09:21 PM #17
good question sir.. hope somebody can answer.. but from my previous experience.. i always use Shell Fuel Save.. but few months back when my suking gas station was offering same price for their next level Shell Gasoline.. (forgot the product) I observed that my fuel consumption went bad.. Haven't tested it again since tipid mode tayo :D
