Results 21 to 30 of 30
- Aug 2007
- 675
September 26th, 2007 08:45 PM #21I read sa isnag newspaper article before that 55km/hr was the optimum speed to save gas. Pero I guess this will depend on how aerodynamic your car is.
Before oil liberalization, my dad used to teach us never to go up to Tagaytay with a full tank because masmabigat yung fuel tank. We'ld only go up with half a tank or less then refuel na full when we get to the top.
Today, this might not apply anymore because masmahal na gasoline sa tagaytay than Manila
September 27th, 2007 08:11 AM #22
Not a majority... just a lot of vehicles are going to the area. But a lot are just passing through on their way to Katipunan and elsewhere.
Maybe it is still better to have just one bottleneck as compared to having two or three bottlenecks scattered the length of Libis, like before the u-turns were closed.
September 27th, 2007 08:13 AM #23
- May 2007
- 101
September 27th, 2007 01:43 PM #24
September 27th, 2007 03:17 PM #25
Like I said, it still better to have just one bottleneck than the 3 or more bottlenecks that used to happen when there was more u-turn slots at Libis. The reason why multiple u-turns will NOT work at Libis? A good number of people simply do not know HOW or WANT to use a u-turn slot properly resulting a bottleneck of vehicles at the u-turn areas.
September 27th, 2007 04:27 PM #26
+1 on that.
While the traffic going up to Katipunan now is pretty bad, it's preferable to having a huge bottle neck at three different points like before... and less stressful when people aren't cutting across four lanes of traffic to hit their u-turn slot, heedless of who or what they might accidentally hit or block...
For those Eastwooders who've been affected, I suggest petitioning the re-opening of the intersection... with a properly programmed light, it shouldn't be such a problem anymore. The huge buildup from the light before was due to the fact that there was no enforcer there, so vehicles could pile up across the intersection as people went through despite it being crowded on the other side...
But then again, the Ortigas flyover is only a kilometer down the other way.... it's only an extra 0.2 liters of gas (2kms) for a few hundred Eastwood people versus a savings of maybe 0.05 liters for thousands of motorists who are just going through. And that saving adds up, in the long run.
- May 2007
- 101
September 28th, 2007 02:57 PM #27yup! one bottleneck is better than 3 of course!
in the case of libis if the intersection would just be reopened, then its gonna be a u turn slot also that is properly positioned bec its strategically positioned in the middle of libis, and as mentioned above, it should have a working traffic light and should be manned atleast during the rush hours. then it might even eliminate the bottle neck problem at all, maybe a slow moving traffic (but constantly moving) but its better than having a bottle neck that will potentially result to a heavy traffic pag mashado na madami nagpileup like whats happening these days during the rush hours
September 28th, 2007 04:39 PM #28
The point of having u-turns instead of stoplights is to cut down the need to have people located at those intersections and keep traffic flowing at all times.
Having a stoplight/intersection would not solve the problem but make it worst.
The real problem is the lack of flow at the Katipunan side of Libis. The road is too narrow to handle peak time traffic loads. Widening the roads around the existing u-turn will help increase traffic flow.
September 28th, 2007 04:44 PM #29
They could remove the roundabout re-routing underneath and install a stoplight there.
The big problem is the "pinch" at the top of the flyover. You have people trying to go to Katipunan (flyover-to-underpass) and people trying to go to Boni Serrano (flyover-then-turn-right to go to intersection).
People get bottled up there because of the stoplight at the top. Since the opening going there is now just a tiny slot (which they did to keep people from hogging the bridge while turning right), people are jammed up at that slot... because... obviously, people are hogging the bridge and turning right from both the left and right lanes of the bridge.
Close up the slot. Make the Boni Serrano people (that includes me) take the underpass. Remove the complicated routing there and put a stoplight for people to follow. But this will make traffic build up on the Marikina side, though...
October 1st, 2007 01:40 PM #30
mas ok yata kung full tank na lang kung can afford naman para less trip sa gas station.. lalo na kung tulad namen na loyal sa isang gas station, petron.. ever since we bought the car, un na kasi ang gamet namen.. unless paubos na ung gas tapos wala talagang makitang petron.. kesa tirikan kami, pa-gas muna ng 100 sa ibang gas station..
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
