Results 11 to 20 of 110
October 30th, 2009 01:16 AM #11
UNLOAD. Yup, all the junk in the trunk does eat fuel. You can always bring a tire repair kit which is lighter than a spare tire and if you only do short distances this will do.
RELAX. Drop the ego. Drive in a relaxed manner and keep the foot off the gas pedal. No need to be a snail but do keep a consistent and safe speed.
N+Hand Brake when stopping. Not only will you consume less fuel, your brakes will last longer. Your hand brake will wear faster though.
Use energy efficient tires. Check Michellin. Others also have similar tires. And keep these properly inflated.
Keep the car in tip top shape. Clean air filter, flush ATF once a year (some do it every three months!) and check your power steering for leaks and fluid. Also remember to have your car properly aligned (lalo na pag luma na yung oto).
- Jun 2009
- 194
October 30th, 2009 01:43 AM #12learned much by reading this. i drive a 09 city, 1.5E and im guilty of hypermile, like what sir ehnriko pointed out. wont do that again. thanks a bunch guys.
October 30th, 2009 02:44 AM #13
YES!..i even remove the 3rd row seat completely...
sometimes...
don't just pull the hand brake up to the point that it's difficult to retract..
proven theory...there are really tires that are fuel effecient.
this i never did for the span of three years......but i do regular tune ups.
October 30th, 2009 05:28 AM #14
lm723,
don't overcool the engine by removing the thermostat. it also disables the overdrive mode and prolongs the torque converter lockup. by overcooling, you are wasting the necessary heat to convert from heat energy to mechanical energy. lighter paint color also affects mpg by reducing the cooling load to the airconditioning or climate control.
jick
November 18th, 2009 12:39 AM #15
No hard acceleration, no hard braking. Use airconditioning sparingly. lalo na ngayon malamig na sa umaga or sa gabi.
- Jun 2007
- 135
July 30th, 2010 09:56 AM #16* ehnriko
Just an inquiry sir. I read my 2005 Altis' manual and it said that don't put the transmission into 2 and L for a long time when negotiating an uphill as it will put uncessarry stress to the transmission causing it to get damaged. Well I understand 1-2mins of going uphill is not a long time.
But what about the Talisay going-up Tagaytay route. WOW thats more or less 10mins estimate (10mins that is if there is not line of cars going uphill) of very steep zig-zag uphill road.
I passed that route sometime this summer and BOY did my Altis 1.6E felt the challenge. There were 3 of us, me my wife and her sister. There was a car in front of me which was slow so I somehow lost momentum on certain areas...bad trip nga.
So what would be the proper way of attacking a steep uphill like the Talisay to Tagaytay route? Do we need to go L and 2 all the way? Do we have to turn-off the Over Drive also while in L and 2?
July 30th, 2010 10:03 AM #17
^^^ My suggestion is just to turn off the "Overdrive" in regular D mode....There should be no issue in your climb..... I am very familiar with the Talisay to Tagaytay climb, bro. It is a great driving 'experience', especially since I am driving a van..... (Did you buy some tawilis and maliputo from the vendors near Taal Lake?).....
10.4K:shazam:
July 30th, 2010 11:57 AM #18
Generally, in areas with uphill roads, simply turning off the O/D (overdrive) would be enough. There isn't need to manually shifting to "2" in most cars.
But in some older A/T cars, the tranny will "hunt" between gears in certain specific conditions. To avoid that, drivers simply shift down to 2 or even L.
So unless you can feel your A/T tranny "hunting" between gears, simply putting it to D (with OD off) will be good enough. It will shift by itself to a lower gear when it is needed.
July 30th, 2010 12:31 PM #19
1. light foot on the pedal
2. pull up your foot from the gas pedal when approaching a stop sign or a curve
3. turn off the air con when you're about to arrive to your destination
4. N for short stops, P for parking
5. regularly check your tires--underinflated tires are a no no
- Jun 2007
- 135
July 30th, 2010 01:52 PM #20Hahaha. No we were not able to buy tawilis and maliputo
Yup I did run it in D and O/D off. But sometimes when the car up front slowed a little, I put the car to L and 2 to gain momentum and D again.
I turned-off the aircondition also.
Pero iba talaga. Grabe yung route na toh. During that day I thought what I did was a big mistake grabe. Hahahahaha.
Before kasi we went that route, but on a Nissan Safari. So straight-6 diesel naman so panis! We were 6 then.....so I was sad for my Altis. Hahaha parusa for the car.
Working na MMDAs. MayHulika. Only for NCAP violations
SC (temporarily) stops NCAP
