Results 11 to 20 of 21
- 20
October 31st, 2002 01:36 AM #11if turning the engine off while filling up is to avoid static.. etc that could lead to an explosion....then turning it on would be much more dangerous because electricity would flow through the engine's electrical parts and that the gas is now inside your vehicle and it is flowing through the gas line ....wouldnt that be more dangerous?
and if smoking too is prohibited then why are there people outside the gas station's convenience store having drinks and smoking?...sometimes i wonder...
- 82
October 31st, 2002 01:47 AM #12Originally Posted by mmda
tinawag ko nga yung isang attendant at sinabi kong sitahin yung mama. ni yung guwardiya timang! wala man lang malasakit. :x
- 237
November 1st, 2002 12:32 AM #14necessary ba tlga?hmm.....il try to change my habit nga...tsaka tinatamad ako magpatay ng cellhpone once nasa loob na ko ng gas station...kasi pag pinatay mo il would cause static na naman so better leave it kesa papatyin mo ince nasa loob ka na ng gas station...
November 1st, 2002 12:37 AM #15
well, i don't know about that static from the car's systems... but there must be a good reason why gas stations all over the world advise customers to turn off their engines when filling up
- 400
November 1st, 2002 12:46 AM #16some food for thought:
won't an "off" cellphone be even more dangerous than one that's turned on? at least if it's on, current flows in a closed loop through it. static will that gets caught up in this flow will be quickly consumed by the phone's electronics.
however, when its off, the screen, the battery act as small capacitors ready to discharge static. same principle as a television. when you switch off your tv, you can literally feel the static discharge that isn't there while it's on.
November 1st, 2002 12:50 AM #17
diba yung "danger" ng cellphones ay yung threat of an oncoming signal igniting the gas fumes? (although someone did say that cellphone emissions won't ignite gasoline...)
- 400
November 9th, 2002 03:23 PM #18diba yung "danger" ng cellphones ay yung threat of an oncoming signal igniting the gas fumes? (although someone did say that cellphone emissions won't ignite gasoline...)
- 10,620
November 9th, 2002 04:08 PM #19ako i turn off the engine kasi wala naman pop up knob sa fuel and naka on ang phone kung may tumawag siguro deadma na lang muna.
November 9th, 2002 04:50 PM #20
splerdu,
radio waves ba yung cellphone? what's all this hulabaloo about cellphone radiations then (which are said to cause everything from gas station ignitions to cancer)? crap?
high idle RPM at engine start
