Results 1 to 11 of 11
    Oct 2004
    I picked up these arguements from a British program. Wonder if it these cliches holds true in the Philippines.
    Arguement 1: diesels are cheaper to run
    Arguement 2: there's a tax advantage to diesels
    Arguement 3: diesels depreciate less quickly
    Arguement 4: diesels are slow and boring to drive
    Case to case basis pa din iyan:
    1. Yes, it is cheaper to run (compared to our V6 Montero).
    2. No. Pareho lang halos ang SRP ng Montero V6 at local GEN II
    3. Yes. Lalo na yung mga Benzes
    4. Depends on how you drive.
  3. #3
    the diesel BMW X5 and the 330d ain't slow... same with the newer batches of CRDi engines... loads of torque and accessible at low - mid rev ranges.
    Oct 2004
    ^^ locally available ah. afaik 330d is special order basis.
    The Sorento is also a blast in its own trucky way.
    C! Magazine's BMW 530d v Merc E320 comparo
    the BMW won.
    May 2005
    Diesel engines are slower than Petrol. But gives very good fuel economy, Diesel fuel are cheaper gas. Diesel is good for towing because of its torque. but not known for its quickness. If diesel is were that fast. it would have been entered in various races.
    Quote Originally Posted by andre
    think again dude
    "volkswagen unveils golf V tdi race car"
    http://www.streetracersonline.com/articles/golfvrcr/
    eto specs nya
    Engine capacity (litres / cc): 2.0 / 1968
    Configuration: 4 cyl, 16v
    Engine management: Volkswagen with Superchips mapping
    Power output (PS * rpm): 210 * 4,000 (standard model 140)
    Max torque (lbs ft * rpm): 330 * 1,750 (standard model 236)
    Drive: Front-wheel drive
    Gearbox: Six speed, limited-slip differential, RCS gear selector
    Clutch: Sachs sintered metal plate
    Exhaust system: Milltek bespoke system
    Steering: Power assisted rack and pinion
    Brakes: 355mm ventilated front discs, Production ventilated rear discs, Mintex racing pads, ABS disabled, adjustable bias
    Front suspension: KW 2-way adjustable race dampers, height adjustable, Adjustable anti-roll bar, solid bushes
    Rear suspension: Multi-link production suspension, KW 2-way adjustable race dampers, Adjustable anti-roll bar, solid bushes
    Wheels: 8x18in/8x19in BBS alloy wheels
    Tyres: Pirelli PZero Corsa 225/40 ZR18 / 225/35 ZR19
    Weight: 1080 kg
    Lubricants: Castrol
    Air filter: K&N
    May 2005
    "It's definitely a good marketing stunt for Volkswagen."
    ok then... take a look at this...
    http://www.carpignano.ch/Video/red_devil_04_15mb.wmv
    turbo golf III --- 580 HP..... of course you can always say the video was faked.
    watch out... the diesel racers are coming! ;)
    and if i recall correctly, a DDi mitsubishi carisma entered a 24h nurburgring race, along with a gas carisma GT, and both placed nicely. the diesel carisma placed lower than the gas one, pero still respectable.
    forgot the exact details, nasa ralliart website yun dati.
Diesel Cliches
