Results 11 to 14 of 14
October 4th, 2007 10:41 PM #11
^ I know the traditional way is more accurate as compared to the LCD monitors and will try it for more valid results .
As regards to the LCD monitor, it is not my habit to reset everytime I fill up. Actually, I haven't reset it for about 6 months and at the same time, used only Caltex, therefore it is the observed average FC (10.2-10.5 km/L). Then when I changed to Petron when my tank was almost empty, I also did not reset. The observed average fuel consumption for the past 3-4 weeks is 11-11.4 km/L, still no reseting. Same driver, same style of driving. Would that be less valid?
- Jul 2007
- 345
October 6th, 2007 06:35 AM #12shell po ako e, maybe it is time to try iba naman, BIODIESEL? yunpo ba yun deisel na may 1% Biodiesel, or it is something else, where po available yun, kasi alam ko may mix na 1% yun diesel natin sa mga diesel natin sa regular gas station e.. tnx
October 6th, 2007 08:27 AM #13
are there studies made on this? making comparisons with fuel brand? higher FC means bigger savings in the long run. hope somebody can validate this claim. after all, it will be beneficial to all of us.
October 6th, 2007 10:21 AM #14
While the law requires a 1% blend, apparently there is a less known sub-clause or something that states they can blend as low as .7%
This being the case, there are no gas companies actually dispensing diesel with true 1% biodiesel blend.
If you want to play around to find out your ideal percentage blend, you can buy biodiesel from dealers and blend yourself.
Hope this helps.
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
