Results 1 to 10 of 21
February 17th, 2006 01:03 PM #1Originally Posted by philstar.com
February 17th, 2006 02:44 PM #2
Other countries have been using biofuels for quite sometime. In Brazil, they even have cars that run on 100% Ethanol. In Sydney, buses run on biodiesel made from used cooking oils. So why the hell won't CAMPI endorse the govt's biofuel program? They're so full of sh*t.
February 17th, 2006 03:01 PM #3
OT lang ha maganda pala yung secretary ng CAMPI hehe hope she's not a member here...
vehicles running on cooking oils pay a certain tax for using it right?
February 17th, 2006 05:29 PM #4Originally Posted by falken
You still can't run many locally sold brand new cars on more than 5% ethanol without burning rubber so to speak. And almost all 90's and below cars will not run well on an ethanol mix without major retrofitting of gaskets, rubber hoses and fuel pumps.
Ford's set on releasing ethanol compatible vehicles, but no one else has them yet.
The problem is, the Government wants to make 20% mandatory. If you're selling a car that can't take 20% eth, your clients are screwed of their warranties... or you're screwed out of millions in repairs. Either way, somebody loses.
Think about it from another angle, too. You're a low income guy, say a taxi driver. You've got a 93' Lancer. It's your livelihood. All of the sudden, every single gas station is selling a 20% Eth mixture that is sure to cause long-term damage to your engine. And they can't, by law, sell anything else. But you can't afford a new car. What do you do?
It's like the leaded-unleaded thing. While we still have cars that require a certain fuel, the government should make sure that people can still buy the fuel. And that gas stations carry warning tags on 20% Eth mixes stating that only cars built to new eth-compatibility standards can use it.
February 17th, 2006 06:16 PM #5
Niky, I think the mandatory blend is 10% on the 4th year, and at 10% blend Ethanol won't harm anything in your car.
why ethanol? » PERFORMANCE
it's what mother nature would put in her sports car.
Can an environmentally friendly fuel deliver real performance for your car? You bet.
Fuel enriched with ethanol performs in much the same way that regular gasoline does. It’s been in use for decades, with trillions of miles logged on vehicles all over the world. Plus ethanol-enriched fuel actually surpasses regular gasoline in key performance categories!
So it might be just what your car needs.
Gasoline enriched with ethanol contains more oxygen — so it burns cleaner, leaving fewer deposits and keeping fuel injectors and intake valves cleaner. And there’s more.
The facts are powerful.
* Ethanol-enriched fuel can reduce pre-ignition problems (knocking/pinging).
[SIZE=4]* Tests have concluded that ethanol does not increase corrosion, nor will it harm any seals or valves.[/SIZE]
* Ethanol-enriched fuel meets all applicable vapor-pressure standards — to alleviate driving or starting problems in hot or cold weather.
* Ethanol-enriched fuel can tolerate water contamination to a far greater degree than gasoline alone — it absorbs moisture and helps prevent gasoline freeze-up in cold weather.
[SIZE=4]* Today’s cars are built to run on fuel enriched with up to 10% ethanol and are warrantied for its use.[/SIZE]
It’s no wonder that all auto manufacturers who sell cars in the United States approve fuels enriched with up to 10 percent ethanol. In fact, many even recommend it for its clean-burning benefits.
Did you know?
The IndyCar® Series uses a 10 percent ethanol-enriched methanol to power all their cars in the series. The IndyCar® Series oversees many races, including the annual Indianapolis 500.
Hey … if race car drivers use it, just think what it can do for those of us just driving the speed limit.
Learn more about ethanol and the IndyCar® Series.
Fuel enriched with ethanol can be used in other engines, too.
Most motorcycle, recreational vehicle and power equipment manufacturers allow the use of ethanol-enriched fuel in their products without restriction. In fact, Harley-Davidson actually recommends the use of renewable, clean-air fuels such as ethanol-enriched fuel. You should check your equipment’s owner’s manual for more information regarding the use of ethanol-enriched gasoline.
Get more details on how ethanol-enriched fuel works with your car's engine.
Visit the Renewable Fuels Association (RFA) at www.ethanolrfa.org to get specifications, octane ratings, government regulations and other detailed information about gasoline quality.
“Ethanol-blended gasoline has very similar driving characteristics to straight gasoline, except that pre-ignition and dieseling (run-on) are noticeably reduced and acceleration can be improved.”
— from published report by The American Institute of Chemical Engineers
February 17th, 2006 09:57 PM #6
Oops... my mistake on the mandatory, thanks for clearing that up. :lol:
10% ethanol is okay for all vehicles currently built to US specs, but not old vehicles or all local market vehicles. A 10% blend does not have an effect on rubber currently used there, because vehicles there are equipped, by law, to handle new ethanol blends.
I'm pretty sure the new Focus and Civic may accept eth blends, but there are vehicles that may not.Last edited by niky; February 17th, 2006 at 09:59 PM.
- Sep 2005
- 392
February 18th, 2006 09:40 AM #7hmmm.... di ba sabi ng US noon Olive oil is best? tapos ngaun pure virgin coconut oil is better according to tests... kaya lang naging Olive oil kc maraming producers sa US and apektado kapag Pure Virgin Coconut oil ang pinalabas. baka ganyan na naman yan di kaya? Protect US interest ban/control BioDiesel.
What do you guys think?
July 18th, 2007 05:33 PM #8
I was about to open a thread about biofuel at nakita ko 'to. It is really very good topic to explore HOW I REALLY WISH NA TULOY PA SANA ANG THREAD NA ITO... COM'ON GUYS...
Kasi ang gandang lilitaw na tama nga ang hinala ng karamihan ng pinoy na hinaharang lang ng US and/or producer ng FOSSIL FUEL.
Ang daming negative na lumalabs kasi lately eh(matutuwa si niky)..
>>> to produce daw 1.00 liter of biofuel, gagamit ng 0.75L of fossil fuel to proccess it...wheeww
>>> of course kasama na ang tataas ang greenhouse effect.
>>> food shortage dahil, farm land intended for food ay ma-divert sa biofuel production.
>>> Cooking oil price tumaas na raw (report mula Indonisia today 18july07)
But on top of this all ito at sa thread na ito nabanggit na ok naman pala boidiesel.tsssk..tsssk...
July 18th, 2007 05:44 PM #9
Xiaomi E-Car
