Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
    #41
    ot garyq available pa basayo ang biodiesel
    #42
    ei guys,
    u can load up in philcoa.they have a petron gas pump inside,2% biodiesel mix lang BUT same price naman cya as prevailing rates sa labas!you'll save a lot.medyo hassle nga lang magbayad coz you'll have to fill up 5copies of your order form,load up then go to the 2-3f to pay...tsk..tsk..gobyerno talaga oo,gusto mahirap everything...anyway if ur filling it up,worth it...hope this helps!
    huhu...ako wala na diesel ride,sold my carnival to raise cash...back to sedan & its near-P30/liter gas
    Apr 2004
    #43
    hey!!! check out the "Diesel news" thread... SeaOil is apparently going to start selling a 1% biodiesel blend in its stations!!! Biodiesel gurus... your comments please...
    #44
    Pano naman kaya natin malalaman na may BD talaga diesel nila sa pump?
    #45
    Bigat sa bulsa ang magpalit ng fuel filter lagi sa benz hehe...
    Sep 2004
    #46
    garyq: pare pde ba sa isuzu 4jx1 yan? how bout sa mitsu 4d56? ilan percentage ang normally inilalagay? and how to order? how much per carboy?...hehhe sensya na po daming tanong...
    Jan 2003
    #47
    pano malalaman na may BD na ang mga seaoil pumps?
    #48
    Trooper128,
    Pwede po sa 4d56 yan. I use it regularly sa L200 ko for almost 4 years now. Mas mafefeel mo ang difference ng performance sa 4d56 compared to your trooper.
    Sep 2004
    #49
    Djerms: pare tnx for the info..panu ginagawa mo? ilan percent ang bio diesel? 1% o 2%?
    where ka buy?..do i have to change the fuel filter after a while? un ang sbi dito eh...hehehe
    Jan 2003
    #50
    TROOPER128 ,better if you could check your fuel filter. baka kelanganin palitan. I'm on BD10. (10% mix)
    wulf , sa petron philcoa meron? alin dun ang pumps na meron? kelangan pa bang sabihan ang mga nagkakarga or lahat ng diesel pumps nila meron?
    #51
    Trooper128,
    Im on BD 5%. You only need to check your fuel filter during your initial use of biodiesel. Kasi baka may mga deposits na natunaw ng biodiesel at magbara sa filter. To be safe, just replace that filter. After that, your filter will be as clean as a new one if you use BD regularly.
    PM mo si Garyq dito sa Tsikot. He sells biodiesel. I think he also delivers if you buy more than 4 liters. Anyway, PM mo nalang siya.
    #52
    u have to enter philcoa mismo,not the petron gas station.immediately after the gate there's a small opening on ur left leading to a grassy area that's been turned into a parking lot.enter,park beside the solitary gas pump w/ a huge gas tank behind it.the guy-in-charge is in the small office in front of you.
    Jan 2003
    #53
    what type of gas is in their gas pump? petron ba?
    Sep 2005
    #54
    "Hi guys! Need your help once more...
    My brother is doing this thesis on biodiesel...If its really and advantage or not, and he needs the inputs of us users here sa tsikot. He is having a hard time running this survey coz most of the motorists still doesnt know this product. Kindly give me naman ur inputs:
    Occupation:
    Vehicle driven:
    Biodiesel used since?
    Effects of biodiesel:
    Do we still need it since our fuel here in the Phils are now less sulfur?
    I can set him up with the DOE people involved in this thrust if he is intersted.
    Aug 2003
    #55
    Lex, please tell your brother to access the following, my research on biodiesel here in the Philippines. Meron din dito sa tsikot, pero mas updated sa kabila.
    http://www.kotse.com/forums/index.php?showtopic=2718
    Sep 2004
    #56
    Sir altec, lex888 was just quoting yung opening post in this thread. The "brother" actually belongs to Djerms, the thread starter.
    I would assume na tapos na yung thesis niya by now because it has been 21 months since this thread was started.
    Apr 2004
    #57
    sir altec's finding on issues on filtering of the CME is very interesting. something we should be watchful of. this has been oberved on senbel biodiesel, and *they are looking into bioactive as well.
    http://www.kotse.com/forums/index.ph...pic=2718&st=80
    *altec, jaeger
    #58
    In my experienced po....proven ko na mas maganda pre blend biodiesel ng Flying V.
    Dati, Shell at petron ako...ng minsan nag try pa ako mag add ng Bioactive enhancer, lalong nagumusok ang sportivo ko...
    Pero ng magkarga ako ng Diesel sa Flying V eh , less usok talaga.
    Try ko ulit petron without Bioactive, eh mausok kaya, balik flying v kami.
    Experienced ko lang ito.
    Bioactive, once lang akonag try, bumagsak pa. Full tank ng Ptron Diesel at 1 letir ng bioactive nilagay ko....mausok, kaya nag flying v ako.
Biodiesel users info
