When I still had gasoline cars, I replaced the stock (Nippon Denso or NGK) with Bosch Platinum & just gapped it myself 2x a year. With the stock plugs, I replaced them every 5k. With the Bosch Platinum, sometimes more than a year or whenever I feel like it runs rough already. There are corresponding replacement performance plugs for the stock ones. You can use the best, just as long as it is more superior to the stock ones. Also, it is worth learning to gap them, practice with the old ones.
For newer cars with modern engines, you can't really say the difference between a regular spark plug compared to an expensive one.
You just need to clean them every 5k and change them every 10k. Like in my case usually copper core conventional spark plugs lang nagamit ko dati.
One of the reasons why platinum or iridium plugs are used is because of longer service life. A lot of newer cars takes time to replace the spark plugs. The labor in most cases outweigh the cost of the plugs. I remember when I used to work at a dealership shop, a customer wanted a minor tune-up for a 1990 Cadillac with Northstar V8 and he wanted it done while he waits, I gave his keys back and asked him to bring it back when it's convenient fo him without me burning my arms to replace the plugs on the firewall side. It all depends what car you intend to replace plugs.
The previous gen Jazz was a bit of a challenge when changing plugs. The plugs are located on the other side of the engine which is not exposed.
I am looking at my FXT’s engine and I am guessing it is going to be a b!&£* to replace those plugs!
With some of today's cars, it is easier and faster to replace the igniter of a Boeing 747 to nclude taking the maintenance stand to the aircraft than replacing spark plugs of some cars.
With Subaru's newer designs ... the boxer engine has to be lowered a little to be able to access the spark plugs ...
More and more people are sharing their concern and frustration in replacing some of the newer cars. Even in the '90's, the toyotaprevia, you have to remove the front passenger seat, the floorboard under that seat and you better have a 3/8 drive 6" wobble extension with your ratchet and 5/8" spark plugs socket. Not all cars are that easy to service until you tried them, hence, the longer projected service life spark plugs. Gone are the days when we had flat head engines with large 7/8" drive easily accessible spark plugs even with just an adjustable wrench.
I'm using stock ignition system on my 500whp car with over 30psi of boost and revving to 9k rpm, no ignition related issues. This has been my setup since 2007 when I boosted this car.
I'm using a cheap replacement "circuit" brand ignition coil(600pesos) and a "surplus" ngk plug wires(1500 pesos.) I just used a generic copper bkr8 spark plug.
So yes, you need to talk to a knowledgable tuner and research. Little knowledge is expensive... LOL.
