Quote Originally Posted by dencio1976 View Post
with the newly installed sgi kit from macro, here are my observations so far.
since it doesnt utilize a tps output or air metering output that would tell it's LPG ecu how much air flow/pressure is fed, at sudden wide throttle, it runs really lean. effect, slow engine response as compared to running it on gasoline.
the ecu needs a lot of rethinking IMO. but it's ok for it's 1st stage i think.
I think you'll need to have the LPG kit re-tuned. My kit also performed poorly on it's first day with slow acceleration due to lean fuel settings.
You might also want to check/replace your air filter if it's getting quite dirty.
