Page 33 of 211 FirstFirst ... 232930313233343536374383133 ... LastLast
Results 641 to 660 of 4201
    #641
    Quote Originally Posted by smdelfin View Post
    Hindi ba po ito makaka-affect pag nag-switch ka balik sa unleaded?
    well, not really since the engine's ecu can adjust the ignition timing (to a degree) after a few revolutions to adapt the engine to different fuel requirements.
    Jun 2006
    #642
    ghosthunter, remember my dillema? regarding sa additives na nilagay ko...
    may catalytic converter ang kotse ko... isa pa problema iyun tank walang drain... tsk tsk... dalhin ko sa chevy service... hindi ko alam pano nila gagawin iyun... dami laman pa naman ng tank ko... sayang, sa gasolina, sa oras, at sa abala naidulot... pakilakasan mo pa kailangan ko talaga iyan...
    #643
    Quote Originally Posted by chuaed View Post
    A suggestion. IF you still have the bottle of the gasoline additive (or if you can find another one at the place you bought it), check the label if it's CATALYTIC CONVERTER compatible.
    Sep 2006
    #644
    Is this also applicable to carburetors? Thanks.
    #645
    With regards to carburated engines' ignition timing, yes. The difference of ignition timing between gasoline and LPG is 10 degrees more advance for LPG. This is also true for EFI engines.
    Your choices would be:
    1. retain timing for gasoline and have poor engine performance under LPG.
    2. adjust for LPG and have poor engine performance under gasoline.
    3. adjust somewhere midway between gasoline & LPG for a compromised performance for both fuels.
    Option 1 is what is currently being done by most LPG kit installers.
    Option 2 would mean poorer performance under gasoline (or requiring to use high octane gasoline) but since you are running on LPG nearly all the time, it shouldn't be much of a problem. It would mean you would need to use high octane if you need to run use gasoline without adjusting ignition timing.
    Option 3 just means that, a compromise to use either fuel but not at it's best.
    Note: some EFI engines can self-adjust the ignition timing and others cannot.
    Sep 2006
    #646
    hi there, i am seriuosly considering converting my 1988 nissan sentra to lpg. and i am canvassing now different installers in this forum. however no one ever mentions SKN gas equipments. (made in india daw ito ). they are also installers of LPG conversion kits. just want to know kung meron ng nagtry ng services nila. medyo mura sa kanila 23,500 pesos for my car. ang number nga pala nila 6333480 and 6333438 they are located at kapitoly pasig. kung meron ng nagtry, please share naman the experience.
    Sep 2006
    #647
    Ganito din ba kalalabasan kung after ko magpa-install ng LPG ay magpa-tuneup (at change oil) naman ako? I mean tuneup using LPG na. Thanks ulit.
    Aug 2006
    #648
    tanong lng mga sirs...
    pwede ba n ilagay yung lpg tank sa lalagyan ng spare tire ng lite ace??
    kasya ba? sayang kasi ung space sa likod ng lite ace,baka hindi na malagyan ng balik bayan boxes...
    thanks.....
    Jun 2004
    #649
    Quote Originally Posted by rad11 View Post
    thanks.....
    May mga donut shaped tanks na pwede ilagay sa lalagyan ng spare tire. According to AmbiEnt, they have will this type of tank available by the end of Sept.
    #650
    thanks.....
    NAIADSS do not have a donut type fuel tank... The italian LPG installer has them though.
    Jun 2006
    #651
    went to nissan quezon ave today. sabi nung sales rep na they will be offering italian lpg system by the end of this year
    #652
    Quote Originally Posted by userfriendly View Post
    I assume the factory warranty is maintained even with the LPG kit?
    Jun 2006
    #653
    did not ask had other things on my mind. the service advisor just gave me an out of this world repair eastimate for my car. tipo bang just buy a new car it will be a lot cheaper.
    #654
    so what's the problem with your car and parts to be fixed?
    Jun 2006
    #655
    Its going to be off topic so just check the thread in this forum titled "help sa brakes"
    Sep 2006
    #656
    Nissan in C5/Meralco Avenue is already offering italian lpg system (tartarini brand). According to them, converting an X-trail (with donut tank) will cost 60K plus. Regarding consumption, they said that it will remain the same as gasoline, about 8km/l.
    Nissan Contact Number- +639229783599
    #657
    I'd be a bit weary about anything offered by Nissan Gallery, they're one of the first Nissan dealers to openly promote Khaos hehe... They probably know nothing about the system.
    Jun 2006
    #658
    Quote Originally Posted by louieg View Post
    Mura na yan. I was given a quote by another distributor of tartarini, 80K for my Venture. Torpedo tank pa yun. Kung torodial tank aka donut, plus 5k pa daw. Can't remember kung VAT inclusive na ba.
    Expect consumption to go up by around 15%
    Alam nila yung Khaos, the more people install khaos the more business nila for repairs
    #659
    good point userfriendly hehe, di ko naisip yun ah...
    Tama lang yung 60K IMO kung yung may ECU real-time adjustment ng timing... But I think 50K lang yan tapos 10K patong sa kasa hehe.
    Aug 2003
    #660
    i had a chat with a taxi driver(corolla XL lovelife ung dala) on my way to
    megamall last week....he had some interesting comments about LPG.
    ...but before we go into that, i just want to make it clear na hindi ko sigurado kung totoo ung pinagsasabi niya; i posted the comments here in hopes that someone would verify/refute what he told me
    Here goes:
    -- dati rati, he would use up less than 50 liters of fuel a day, usually mga 42 liters daw. with the lpg kit installed, umaabot ng 50-60 liters per day(imho, there could be a lot of factors. maybe medyo malayo ung biyahe na on that particular day, or matrapik, etc. pwede rin that maybe psychologically he thinks mas mahina hatak ng LPG, so mas madiin tumapak sa gas. dunno)
    -- mas mahina daw hatak when going uphill. dati rati daw, with 3-4 people onboard, with aircon on, no problems daw. ngayong naka LPG, di na daw kinayanan even without aircon
    -- kelangan daw ng "special" sparkplugs pag LPG kit. ung 'ordinary' denso sparkplugs, mga isang linggo lang daw tinatagal; nasisira daw dahil mas mainit daw pag LPG. ung kelangan daw gamitin is some sort of sparkplug that has four prongs/produces four sparks
    -- most alarming of all...kelangan daw mag mini top overhaul every so often. me namumuo daw na layer of soot on the cylinder heads, which needs to be cleaned out regularly(parang months ata ang pagitan?)
    -- finally, and strangest of all, mas madali daw nanunuyo ung lalamunan niya when he started driving an LPG converted unit. i'm not really sure what to think
    don't shoot the messenger peeps, just trying to get opinions from the people who spend the most time driving LPG cars. Sana'y meron pong magclarify nitong mga issues ;)
Auto-LPG Conversion Thread
