I finally got my M3 this afternoon at greenfuel. Thanks to Warren for checking the car himself and team gf. The 35km trip from the shop back home went smooth.
Our Mazda3 had a 60L toroidal tank. But my brother decided to have the LPG kit removed because of tuning issues under LPG.
I have previously posted the pics of the car within tsikot.com for those interested in seeing the setup.
My Corolla has a 65liter cylinder tank. That car can drive Manila to Baguio to Manila using only LPG.
LINK: http://tsikot.com/forums/nissan-cars...version-51318/
It was done at GREENFUEL few years ago. But these days I would suggest going to XOOM-LPG for better service.
LINK: http://tsikot.com/forums/mazda-cars-...version-51322/
I would give your conversion a month before calling it a successful conversion. It has something to do with the mazda3's adaptive ecu having issues resulting in poor performance and hesitations from idle.
I already have previous listed the contact info for Auto-LPG installers. (If people wold just use the search first... hint hint)
LINK: http://tsikot.com/forums/car-economy...59/index2.html
all, will an auto-lpg automatically switch to petrol when I run out of LPG and is it not dangerous most specially when I am on high speed? I would like to drain my LPG so I can accurately see my FC on LPG.![]()
Depends. At worst, if the system will not switch over from lpg to petrol and you run out of lpg, the engine will just feel sluggish and under-powered. Switching fuels at high speed will not be a problem. I have done it many times before.
As for figuring out your FC with LPG, you can use the same full-tank to full-tank method used for gasoline. You don't need to literally use up a full tank of LPG to compute it. Just make sure you are filling up from the same station and pump for best accuracy.
My greenfuel's kit doesn't have auto switch to gas if run out of lpg. I think this is the limitation of the ECU from greenfuel..but others have this capability and already standard for sgi kit as far as i know.
Wag mo lang e empty lage yun tank kasi baka masipsip yun mga dumi sa loob...sakin once a week lang ako nag fillup or pag nag blink na yun light para sa reserve.
isang beses lang ako naubusan tapos parang nag sluggish at prang nagchochoke yun engine tapos manual switch ko na lng sa gas. as much as possible wag ka mag switch to lpg during high speed para panigurado lang.
don't forget to run you car on gas from time to time...once a week for 10-20km is ok.
