The original gasoline tank is still there. The Auto-LPG tank is installed in the trunk.
For SGI-LPG systems, the ecu is programed to start the car with gasoline (and switch to LPG once running) and cycle the injectors every ten to thirty minutes (depending on the program cycle). Some users have requested to disable the gasoline cycle without ill effects.
For my car's Venturi-LPG system (generally not sold anymore), I can decide to manually switch to either LPG or gasoline. Usually I use gasoline for half a day once or twice in a month just to circulate the fuel and activate the gasoline related parts of the car.
Fuel consumption and engine performance will still be the same with SGI-LPG. DO not expect any miracles if/when you have converted your car to LPG.
