Quote Originally Posted by eikichi View Post
I also use gas during start ups and 1-2 kms and prior to shutting off the engine.
Had the same experience with engine having episodes of choking and rough idling for gas. Eventually my engine had starting problems. (Not sure though if this had anything to do with it.) When my car can no longer start, I had it checked and discovered that my injectors were stuffed with solidified gasoline. These were cleaned using gasoline and dried using compressed air and was running fine again.
thanks for the inputs sir. i think we really need to use gas more often than the usual start up and before engine shut off.
i still experience the jerk feeling when driving on gas at any speed, mas noticeable pag mga 70-90kph. do you think i shall have it service at goodyear servitek where they have the equipment for calibrating injector * Php 2400 or just have it clean by your trusted mechanic since sa tingin ko madumi na rin yung sa akin?
now i have idling problems again, ngayon lang ulet nangyari after greenfuel serviced it 6 months ago. mukang kailangan na naman buksan ito para i tuwid yung mga malalambot na bakal.
*BIGMIKE aka warren : based on my experience on your vaporizer units i need to have my vaporizer serviced every 6 months just to fix the idling problems. pano kaya maayos ito? ang layo ko pa naman. Thanks.
