Quote Originally Posted by eikichi View Post
My problem here is that now I am not sure if I am using my lpg kit correctly. According to GF, I should start the car on gas and run for a few minutes then use lpg. Switch back to gas for a few minutes before shutting off the engine. This is how I've been doing it since my kit was installed mid 2008. Now I am contemplating on changing how I run my car. Probably full tank lpg and finish it then use about 2-3 liters of gas continuously then use lpg again till it's finished. What do you guys think? I'm now confused. Repairs were quite costly and I wouldn't want that same thing to happen again. My car is a 1998 Corolla using a venturi kit.
We have pretty much the same setup. (99 Corolla with NAIADSS Venturi kit)
My solution: I just run on gasoline once a week. And I don't just putter around, I floor the accelerator pedal when the traffic is light.
My main problem is gasoline getting stale in the tank. I had nearly half a tank of Shell E10 unleaded that went stale. I had to dispose of it and replaced with Petron XCS.
