it's been awhile since last i posted on this section.
anyway, nabasa ko yung problem about SGI?
yung isang sentra GX 07 namin equipped with SGI nagkaron din ng problems.
1st encounter i had with it was clogged fuel filter inside the fuel tank. you will have problems running your car on gasoline. even worse, it won't start at all since it starts on gasoline and only runs on LPG after it reaches a certain engine temp.
problem is the fuel pump keeps pumping gas kahit hindi naman need ng engine mo as you run your car on LPG. nagkakaron ng build up ng dumi sa fuel tank that way. probably a breakdown(by stirring). nakakapalya din.
solution? i installed a manual switch on the fuel pump. problem solved.
problem with this is since it's manually overriden, minsan makakalimutan. either ayaw magstart kasi nakalimutan on yung switch or hindi naipatay nung nagswitch to LPG na yung engine.
my thoughts:
since may fuel management na ang SGI, dapat nakaincorporate na sa computer box yung fuel pump cutoff which i thought they already did.
pero the best pa rin ang SGI kit conversion para sakin. hindi makulit sa tono generally.
