Page 166 of 211 FirstFirst ... 66116156162163164165166167168169170176 ... LastLast
Results 3,301 to 3,320 of 4201
    #3301
    Quote Originally Posted by quan2boy View Post
    Went to Greenfuel >2 months ago to have it checked and if I'm not mistaken, they just made some adjustments with the vaporizer screw. Since then, my LPG has been flawless...(touch-wood)
    Cheers!
    Tanda niyo pa ba kung anung tatak ng vaporizer na naka install sa kotse niyo?
    To those who don't use synth oils for their LPG rides, i was at ACE Hardware yesterday and i saw they have mineral Mobil Oil (15W-40) labeled for use with LPG engines.
    na try niyo na ba? magkano per liter? im using top1 synthetic oil, dahil matanda na rin yung oto ko.
    Quote Originally Posted by kapitan88 View Post
    matagal na ganito ang naging prob ko, hirap ang idle ko and hard starting talaga, then brought it back to GF then pinalitan nila yung manual valve sa intake ng lpg, yung screw type na blue plastic valve, di naman halos nagbago ang pag start, kaylangan lang na normal operating temp na (half nung temp guage) before i switch to lpg, otherwise, hirap ang idle ko til mag stall, worse is yung may parang uutot sa system na parang makaclog na at ayaw na mag start totally sa lpg. to be continued sa reply sa baba . . .
    sa mga nakapag palit na ng parts which is out of warranty na, pwede ba natin i compare ang prices dito? (not sure if allowed ito, pero just to give an idea how much ang expected gastos natin pag may nasira.)
    Solenoid valve (Petrol) 1K (discounted from 1.5K)
    kadalasan i wait for the engine temp to go normal (1/2 gauge) before switching to lpg para smooth ang takbo when lpg is use.
    about sa vaporiser repair 1.5k ang charge ng GF. nakita ko na kung pano nila binaklas. hinde naman ganun kahirap i balik kaya next time ako na siguro ang gagawa nito.
    ito nga lang ang problema pag may sira ang lpg natin, walang available na parts sa ordinary car parts shops.
    #3302
    Its around P 800+ per gallon.
    Oct 2009
    #3303
    pwede ba lpg sa automatic na car?
    anu pala best na LPG conversion kit?
    thanks
    #3304
    Quote Originally Posted by gigor View Post
    It doesn't matter if your car is automatic or manual.
    Depends on the engine type you have (carb or efi).
    typically:
    carb - venturi kit type
    efi - sgi kit type
    As for which company to do the conversion, I would suggest one that is conveniently located to you because if you need to have it serviced, the nearer the shop is to you, the better.
    Aug 2007
    #3305
    GOOD DAY MGA Sir!!!
    long time no post..hehehe....
    Still with ECONOGAS but becasue of this recent events ....lumubog yung office namin....hanggang tuhod yung baha..........sa 2nd floor...hehehe
    Were renovating the office a litttle...but business still continues...
    Our office tel no. is still out...but you can reach me or txt me at 0922888MIKE(6453) for your inquires or questions...
    Wala ba tayo Grand EB sir GH?????
    Tnx
    Mar 2007
    #3306
    To LPG'ers,
    This thread is 4yrs old and still going. Just want to know if there are any major breakthroughs in the LPG systems (venturi or SGI).
    Hello BigFootoz,
    Your website is down for months. Any plans reviving it?
    #3307
    Quote Originally Posted by straker View Post
    To LPG'ers,
    There is still some R&D work being done for Auto-LPG for diesel engines but nothing ready for consumers.
    One thing to note though. Since Auto-LPG converted cars do not use gasoline as much, your tank of gasoline will last many weeks or even months. In that case, you might want to avoid E10 gasoline because this type of gasoline tends to "expire" in three weeks (in my experience). Symptoms of expired gasoline would include rough idle and low power when running on gasoline mode.
    Mar 2007
    #3308
    In your opinion, would an LPG install lower or increase the resale value of your car?
    How much is the cheapest EFI emulator in the market now? And where do I get it?
    #3309
    Quote Originally Posted by oceanrider88 View Post
    Depends on the buyer and what kit you installed. Getting the cheapest kit might not be the best option if you want best resale value.
    You can try calling the listed installers.
    AUTO-LPG Installers Contact Information
    http://tsikot.yehey.com/forums/showthread.php?t=50159
    #3310
    Can anyone tell me if this is a good price? I called Green Fuel and they quoted a price of Php39k for an LPG kit installation on a Nissan X-Trail, plus Php3K if I opt for the toroidal tank. Installation takes about a day, provided I bring it in early in the morning.
    #3311
    Quote Originally Posted by Altis6453 View Post
    The price is just right for the SGI-LPG kit. The toroidal tank is a good option to get if you want to keep a flat cargo area in the back.
    #3312
    Thanks, GH. I've been hearing good things about Green Fuel, but a lot of people also swear by Macro for being generally reliable.
    #3313
    Same price i paid for my kit last year.
    Aug 2008
    #3314
    What are the advantages of the split fuel system (e.g. econogas vogas split fuel system where gas is injected simulteneously with lpg) versus the SGI system? Do the advantages offset the higher cost?
    I am planning on converting a 98 camry.
    #3315
    Quote Originally Posted by aysiyadi View Post
    Some engines do not respond well with LPG. They can idle rough and have poor performance. In these cases, dual-fuel LPG+petrol injection system are recommended. It is more expensive.
    A Toyota Camry takes to LPG very well. So just get the SGI system.
    Mar 2007
    #3316
    Thanks. Can you guys post pics of your lpg gauges / switches please? I am curious to see how it looks and if there are gauges that would fit oem blank switches. Thanks
    #3317
    You can search via tsikot/google search:
    Nissan Sentra N16:
    http://tsikot.yehey.com/forums/showthread.php?t=51318
    Honda CRV gen2:
    http://tsikot.yehey.com/forums/showthread.php?t=51320
    Honda City iDSi 1.3L:
    http://tsikot.yehey.com/forums/showthread.php?t=51321
    Mazda3 1.6L:
    http://tsikot.yehey.com/forums/showthread.php?t=51322
    Mar 2007
    #3318
    What is the current fuel consumption of your camry city/highway if I may ask?
    Mar 2007
    #3319
    Is that the only kind of LPG switch available?
    Are there LTO incentives for LPG users? Like lower registration for LPG equipped vehicles?
    #3320
    depends on the installer's kit. The links I posted are the ones used by GREENFUEL. Other installers use a different style switch but overall similar in look and function.
    NAIADS older venturi kits use a switch/LED display that displays numeric percentage for the tank level.
    You wish. This is the Philippines. No such thing.
Auto-LPG Conversion Thread
