^I think you still need a gas tank (even just a small one). AFAIK vehicles equipped with LPG, still need to start up using gasoline and until the engine warms up a bit. Only then can the fuel system be shifted to LPG (from gas).
Quote Originally Posted by n5110 View Post
not sure how the (TAI taxis) do it but according to them they totally remove the gas line. hinde ko alam kung pano nila napapa andar ang kotse from a cold start.
I do it everyday (cold start on LPG). I use the venturi type LPG kits. It just takes a few more seconds to crank the engine before it starts, otherwise it starts normally.
Only SGI-LPG kits need to start with gasoline but even then, I also have managed to start our car on LPG back when the gasoline fuel pump wasn't functioning. You just have to crank once and then wait for the LED light to tell you the LPG system was on "lpg".
