Quote Originally Posted by dragonmate View Post
I have a recurring engine stalling problem which I can't figure out. It always happens after a long drive of about 2 hours or more. After I park the car for a long while, say about an hour, and I drive off again, I will run less than a kilometer and the engine will suddenly stall. It won't re-start unless I turn off the SGI, and run on gasoline. Usually, it takes at least a half day before I can turn on the LPG again.
At first I suspected a clogged fuel line. But I noticed that the stalling only happens under the very same circumstances. My typical daily drives are trouble-free.
Anyone else experiencing this? Any guesses?
Yep. Experienced this before.
What I've done is to switch to gasoline before turning off the engine. So far it's working for me. Before kasi, I get the stalling issue about every month. Tapos I bring the car to Greenfuel and they quickly fix it (I think mostly cleaning lang naman). Kaya lang hassle din palagi pumunta sa Greenfuel kasi out of the way for me.
Then one day, nagpalit ako ng LPG ng kalan namin. Tapos ayaw magsindi. Apparently, I had to reset the safety device attached to the regulator to resume gas flow. I figured baka ganun din sa SGI kit ko. Thus, I began switching to gasoline before turning off the engine in the hope that it somehow resets some "safety device" in my SGI kit. So far, 3 months na, hindi pa nagloloko ulit car ko (touch wood).
I suggest you try this technique. Downside lang is you need to remember to switch back to LPG the next time you use the car as the auto-switch to LPG is disabled when you turn off the engine on gasoline.
