Page 140 of 211 FirstFirst ... 4090130136137138139140141142143144150190 ... LastLast
Results 2,781 to 2,800 of 4201
    May 2007
    #2781
    Quote Originally Posted by bigMIKE View Post
    Also just concluded conversion on a fleet of trucks to run on Recycled Vegetable Oil if anyone is interested
    Hi bigMike! Yes I am absolutely interested. I don't have a fleet but do have an old Benz Diesel that has been waiting for such a development.
    Do you mind PM'ing me the technical details? I would appreciate any information regarding a consistent supply of recycled vege-oil as well.
    Thanks,
    steve
    May 2004
    #2782
    Baket ganun pag naka LPG ako ok yung takbo ng kotse ko pag naka gas hirap na hirap... nag jujurk specially at low RPM when you floor it naman nag jujurk sa simula tapos biglang harurot naman... matic po car ko... ano kaya problem?
    Aug 2006
    #2783
    Quote Originally Posted by 1997 View Post
    Clogged gasoline line, either fuel filter needs replacement or dirty injectors.
    #2784
    Possible causes:
    -dirty injectors
    -clogged/dirty fuel filter
    -bad or stale gasoline
    Apr 2008
    #2785
    Quote Originally Posted by vanleano View Post
    dunno if this is OT..but am contemplating on coverting my accord to LPG..how much would it cost me kaya??and what's the best kit so far na bang for the buck????
    Go to Green Autogas in Minanao Avenue. I don't know the price now but I am sure you will be satisfied with the kit, installation and performance.
    Apr 2008
    #2786
    I wonder if this has something to do with sparkplugs wearing out sooner on some Auto-LPG equipped cars?
    Side note:
    http://www.bosch.com.au/content/language1/html/5673.htm
    Check the "Suitable for LPG" note on these set of sparkplugs... do they know something we don't?
    The lifetime of spark plugs under LPG is around 80% Also they say that stock plugs (factory installed ones on your car) are best for LPG; best in terms of price and performance.
    #2787
    di ko pa na experience ito. gaano katagal niyo ba ginagamit ang car on gas before switch over to lpg?
    my last full tank was before i converted the car last last week of august, until now i still have 1/2tank. will this cause problems with rust, stale gasoline? damge fuel pump etc. magastos din magpalit ng ganitong mga parts.
    #2788
    Quote Originally Posted by n5110 View Post
    hi n5110! actually this does happen. I would suggest running your car on gasoline once every month maybe for a good 10-20km. This makes your Petrol injectors work thus preventing clogs. Stale gasoline that has already lost its octane will definitely make your car jerk on low rpm..parang walang hatak, then paglampas ng 2000-2500 rpm tsaka hahatak ng medyo maayos.
    #2789
    Quote Originally Posted by filchaser View Post
    Actually not the factory plugs, it seems platinum sparkplugs last longer than others when used with LPG. Iridium sparkplugs seems to suffer bad tip erosion when used with LPG.
    I am wondering if TORQUEMASTER sparkplugs with either unique circular design might work well with LPG.
  10. #2790
    Same case for me, I've posted this issue several pages back. I think my air-fuel settings are optimal for my EROOM kit. I suspect that lean na kapag switch sa gas. I run LPG 95% of the time, so I tolerate it (I only use gas for about 15kms once every week).
    Weird lang sa akin, gas will run well for the first few kms immediately after switching (for example going to work). Pero next time I use gas (e.g. on the way home), dun na lumalabas yung delayed response ng gas. I have to step on the gas pedal hard, and delayed and gradual ang pag-taas ng RPM.
    May 2004
    #2791
    Quote Originally Posted by paolorenzo View Post
    baka sa Eroom kit yung may problem... Wil have my car tune up then if the symptoms is still there will bring it back to Eroom... Before kasi pag start up lang medjo hirap sa Gas then gradually gaganda na yung takbo but now all the time na...
    #2792
    I tried to run on LPG up to almost empty. Then nagpakarga ako sa Total. They were able to fill up to 49+ liters. I have a donut tank of 55L. Puede pala sya i-fill-up to 90% of the capacity??
    #2793
    Quote Originally Posted by quan2boy View Post
    yup, you can go 90% fill capacity. It simply depends on the cut off at the station you are refilling at.
    As for me, weirdly, ever since i have my filler valve replaced, my max fill level has shifted from 80-85% to 90% based on the mechanical gauge on the tank.
    #2794
    Hi guys, Been hearing a lot of stations filling more than the effective capacity of tanks. I don't know if these stations have higher pressure to push more lpg into the tanks or they just have a faster meter.
    But just the same to be on the safe side, please keep it at 90% maximum. Tell the gas boy to stop filling once you reach this point and never go back to that particular station again if this happens.
    Aug 2006
    #2795
    Some station attendants will ask if you want "NoFlow" or "Full only". The attendant explained to me that Full only is when you hear the tank making the hissing/whistle sound, it means the LPG tank is about get the NoFlow status on the pump meter.
    #2796
    I observed Cleanfuel station congressional cuts off at 75% while total alabang roughly 90% of my tank capacity of 40li. hinde ba delikado itong sa Total station? please advise. Thanks.
    one more thing. bakit walang rollback sa LPG?
    Aug 2004
    #2797
    Mabagal ang rollback. LPG is only semi-dependent on crude oil prices, since crude oil is only one of the sources of LPG.
    I don't rightly know... I've noticed that I can get a lot more LPG at Total... but I don't know if it's the weather or the pump... parang matagal bagong mag auto-cut-off.
    Aug 2006
    #2798
    Mabagal nga ang cut-off ng Total, madalas naiinip ako pinapatigil ko na lang kahit di pa No-Flow.
    Usually Total auto LPG pumps has this valve regulator just before the filler gun, some attendants will adjust it fully open and this is the reason for overfills beyond the 80% safety limit, but when the regulator valve is positioned halfway then the NoFill will come very slow but will give you assured 80% cut-off.
    SeaOil pumps don't have this regulator valve before the filler gun so it fills beyond the 80% safety limit.
    Oct 2003
    #2799
    Naghahanap ako ng exact conversion ng LPG from kilo to liters: iba-iba ang value:
    1 Kilogram of LPG = 1.79 liters (Water Capacity)
    1KG LPG = 1.82 LTR (DEPENDS ON TEMP.)
    1 kg LPG is equivalent to 1.66 litre LPG
    ano ba talaga?
    Oct 2003
    #2800
    double post
Auto-LPG Conversion Thread
