Quote Originally Posted by eikichi View Post
I noticed just this week when running around 70 kph that my car seems to have a difficult time at that speed. Parang nawala yung pick-up niya unlike the time when I was using gas. I was not able to notice this before because I seldom go higher than 80 kph in metro traffic conditions. Is this normal or there's something I need to check or need for retuning?
Performance should be similar. Some tuning is probably required but it would result potentially slightly higher fuel consumption if you were running lean before.
Also, do I need to use gas before and after using LPG? I try to run on gas for a few minutes on start up and switch to LPG. Before turning the engine off, I also try to run it on gas for a few minutes too. Am I doing this correctly or do I need to change the steps?
You don't need to run on petrol before shutting down.
My kit's running condition is fine at low speeds and rpms. FC is also acceptable at around 9.5 km/li on LPG as compared to 11 km/li on gas. I think I will still need to get more samples of my FC to get a more accurate reading since I've had only a number of fill-ups. My kit is an emulator on a 98 Corolla GLi.
