Page 71 of 211 FirstFirst ... 216167686970717273747581121171 ... LastLast
Results 1,401 to 1,420 of 4201
    Jan 2003
    #1401
    nice read on the different types of LPG SYSTEMS
    http://www.go-lpg.co.uk/which_conversion.html
    sirs' which one of the closed loop system do we have here in the Philippines? The system uses a single point mixer with fuel mixer? Or the multi point gas injector system?
    #1402
    For carburetor engines, the only conversion that can be done is the mixer system or open loop system
    For EFI engines up to around yr 2000, you can choose an open loop system or a close loop system. Both systems still used an emulator controller. The difference with the above two system is basically the closed loop system requires and oxygen sensor. As most fuel injected cars in the Philippines prior to yr 2000 do not come with an oxygen sensor the open system is used. In occassions when there is an oxygen sensor in the can then the closed loop system can be used
    The other system mentioned is the multipoint injections system or the "SGI" system. This system directly injects lpg into the engine. This is actually the closest system to fuel injection. This is superior to the open and closed system as there is an ecu that is added to the engine that copies your original injection system. This delivers precise amount of lpg to run your vehicle efficiently. Moreover, there are safety features as well as maintenance features that are included added in this system
    If you have any further questions call me at 09228231270
    Aug 2003
    #1403
    Ano ba ang tamang system for Revo 1.8? How much aabutin?
  4. #1404
    Quote Originally Posted by raspi View Post
    Up ko lang. I have a Revo 2.0 (1RZE), and still contemplating on conversion. Sa Revo engine (old EFI), tingin ko pinaka-ok yung closed loop. Sabi rin ni bigMIKE, hindi puwede SGI kits sa Revo.
    *bigfootoz, meron ba kayo torodial tank? How much closed loop system for the Revo 1RZE (with toroidal tank sana)?
    Aug 2007
    #1405
    Quote Originally Posted by webmiester View Post
    Masmura na ang SGI ngaayon, hindi na siya P55k. I got mine last october for arnd P48k... pero now meron nang mga P34k na SGI systems, so ROI of those things would be faster
    Oops, mali yata ako. 39k pala ang sinabi ni bigMike, hindi 34k... pero who knows? Baka meron ngang 34k na SGI... The closed loop systems sound really good though...
    BigMike, I was kinda thinking kasi my car is a 1997 model, it doesnt come with oxygen sensor... however, I found the manual for its engine, and meron ngang slot supposedly for an oxygen sensor. Can I just buy an oxygen sensor, attach it and wire it into the SGI's control module?
    Aug 2007
    #1406
    Quote Originally Posted by sharon View Post
    If you have further questions, you can contact me at 0922-8540525 or you can email me at greenautogas*gmail.com. You can also drop by our conversion shop in the VELCO gas station at 18 Mindanao Ave., QC. In front of Veterans golf.
    Hi Sharon,
    Its so nice to see you here How are you na? You still havent sent me my car's pics... and I still havent been able to visit your new shop since you guys transfered...
    Hey Sharon, I might go to Africa soon for some missionary work. My car runs on an Aldessa SGI system without an oxygen sensor... I might end up staying in Africa for about a year, leaving my car idle.
    Now, I have someone who will run my car every so often so that it's gasoline line wont become stale and its filter wont be busted,etc...
    However, since nobody here knows how to operate my lpg car's system, and since it doesnt have an oxygen sensor (meaning it wont switch to gasoline until the lpg is completely finished), I just usually leave my car on gasoline mode when I go abroad...
    How long can the SGI lpg system be left idle without it having problems? Since it doesnt have a fuel filter and all, I would expect that this can be left idle for a longer time than gasoline. Can I just leave my car in gasoline mode for 1 year while I do my missionary work? Thanks Sharon
    BTW, if you look hard enough around the thread, you'll find your picture here, hehe... I took the liberty of posting your picture with my car since you still havent emailed me my car's pics from your shop
    Also, since my car doesnt have an oxygen sensor, will I expect performance changes if I go up to high-altitude locations such as Baguio? I understand that SGI systems are supposed to readjust the fuel settings based on the atmospheric oxygen content, but since I dont have an O2 sensor, will my engine run lean if I go up there?
    #1407
    Just adding...
    I have talked to the Department of Trade & Industry. Greenfuel is a certified installer of auto-LPG systems.
    #1408
    Actually we do recommend the emulator system for the revo as we think this is the best suitable conversion based on price and efficiency. After all what we are all here for is savings (both installation and fuel). Our emulator system has been installed in a number of revo already including mine so I do have first hand info on this vehicle. Moreover what is the point of installing a SGI kit when you do not use the tools (obd and/or oxygen sensor) needed by the ecu to run your vehicle efficiently.... As for euro certification, most kits from europe do undergo this certification whether it is from italy, holland, turke, bulgaria etc.....
    At Greenfuel, we offer all year round price of 39K for sgi 4 cylinder and in order to satisfy all you tsikoteers we'll be throwing the option of toroidal tanks free of charge to the first 50 units that come. Offer last until supply lasts.
    Like the other installers, we are also recognized by the Dept of Trade and Industry.
  9. #1409
    Quote Originally Posted by bigMIKE View Post
    ...and in order to satisfy all you tsikoteers we'll be throwing the option of toroidal tanks free of charge to the first 50 units that come. Offer last until supply lasts.
    Hi bigMIKE. Is your promo (toroidal tank) for SGI kits only?
    Also, how long ang installation time for the Revo?
    Mar 2007
    #1410
    hi. guys. how bout for the mazda powervan 2.0liter gas? what system to use & how much? how much to add if w/ toroidal tank ? ilang liter capacity nun? syang kasi carrying capacity likod ng van pag cylindrical tank. mababawasan ang utilty ng van pag may dambuhalang horizontal tank thanks sa mga replies ng mga dealer. ganda ng van ko, suabe & reliable. kya lang 5km per liter kahit anung pagtitipid gawin ko
    Mar 2007
    #1411
    hi. guys. how bout for the mazda powervan 2.0liter gas? what system to use & how much? how much to add if w/ toroidal tank ? ilang liter capacity nun? syang kasi carrying capacity likod ng van pag cylindrical tank. mababawasan ang utilty ng van pag may dambuhalang horizontal tank thanks sa mga replies ng mga dealer. ganda ng van ko, suabe & reliable. lumalaklak nga lng ng gas. 5km per liter na d best n kaya kahit anung pagtitipid & econorun gawin ko
    Aug 2007
    #1412
    Sa mga van, whose spare tire is under the car chasis, pwede bang doon na lang ilagay yung torroidal tank?
    Mar 2007
    #1413
    it is the 1998 mazda e2000 gas2.0 liter non-efi ata, yung dual sliding door. non efi cya ata kya di pwede sgi....
    Sep 2006
    #1414
    Meron na po bang nakasubok magpakabit ng lpg kits sa alpgas at pasig? ok ba sila? kindly give feedback naman sa mga nakasubok na
    tia
    Aug 2007
    #1415
    Quote Originally Posted by paolorenzo View Post
    Good day Sir,
    as of now wala pa kaming torroidal cylinders...but hopefully within 2 months shipments will be coming in..
    Our system uses a Feed back mixer System CLosed-loop. price starts a 25K for cash pruchase...
    thnx
    Apr 2008
    #1416
    Hello! I have a 2000 Ford Lynx A/T. I am a victim of its fuel consumption and I wanted to sell it. Problem is resale value for Ford Lynxes is just too low. Thinking of converting it LPG and just use the car instead. Niky, thanks for your input on some of the Ford problems! Any comments on auto lpg? Price, performance, ROI.
    #1417
    Quote Originally Posted by filchaser View Post
    What is your typical fuel bill for a month?
    SGI LPG kit = P39,000 by GREENFUEL (full automatic switching function)
    Closed Loop Mixer based LPG = P25,000 by DENSO
    Open Loop Mixer based LPG = P18,000 by GREENFUEL
    Donut tank available from Greenfuel.
    Performance for SGI kits would almost match gasoline performance. Mixer type kits have a a slight but generally unnoticable performance drop, especially nearing the redline of the engine.
    Oct 2003
    #1418
    what is the best kit for a 1998 Toyota RAV4?
    Saan linalagay yung tank? puede ba toroidal sa floor then takpan na lang para magamit pa yung storage on top of the toroidal?
    How much?
    Thanks in advance..
    #1419
    bigMIKE,
    is the year round 39,000 sgi kit with toroidal tank offer also good for the fortuner (2.7L, 4cylinder)?
    if it is, i'll schedule of fitting one by this month. thanks!
    #1420
    Quote Originally Posted by tebs View Post
    bigMIKE,
    :beer::soon::imbey::fuzzy::error:
Auto-LPG Conversion Thread
