Which is actually better when going eco-friendly (and wallet friendly as well)?
- Biodiesel which is made from vegetable oil and a catalyzing agent. Clean * water free vegetable oil is mixed with an amount of the catalyzing agent and left overnight. The resulting liquid is biodiesel. If there is water contamination, you are left with soap. The biodiesel can be used directly as fuel but is not economical because of the high cost per liter. Typically this is mixed with regular diesel fuel at 1 to 5 percent biodiesel to regular diesel fuel. Results in cleaner emissions but a costlier fuel if not for certain tax breaks.
- Used vegetable oil is basically the raw material for biodiesel and essentially a waste material in kitchens. To use this as fuel, the used cooking oil is filtered to remove all particles and food bits. The resulting clean used cooking oil is then mixed 50% with regular diesel fuel and left to stand for an hour or two. If there is no separation between the mixture, the cooking oil / diesel mix can now be used as fuel. In cold climates, a diesel fuel preheater would be required because cooking oil tends to thicken as the temperature goes down. Here in the Philippines, the preheater can be omitted.
For me, some of us would actually benefit from recycling used cooking oil into diesel fuel. It would be cost effective since it might be possible to get this for free from restaurant kitchens (if you ask nice enough).
