Results 11 to 16 of 16
April 19th, 2004 09:03 AM #11
the engine size already does something to the fuel efficiency... Glenn gets the same with his Safari me thinks. Try to check your fuel system 9lines, filters, etc) to see if theyu're still good. I also think the SAE 40 oil might have some effect as the oil visco is consistent at 40 grade even when the engine starts up cold... If you noticed, the energy saving oils have a low visco.
- Oct 2003
- 16
April 20th, 2004 11:55 PM #12mga sir ganu po b sa tingin nyo an dapay na kain ng crudo ng pajero 2.5 tdic? matic, 83000 kms na natatakbo? kc sa tingin ko po 7 to 8 km per liter po ang kain nung akin notmal po b ito/
Tsikot Member Rank 4
- Feb 2004
- 1,704
April 21st, 2004 11:02 AM #13that's about right. kasi i have the 2.5 liter tdic na manual and nasa 8.5 to 9 ako. 89,000 lms din ang takbo ko
andy
- 179
April 21st, 2004 11:07 AM #14does the oil viscosity have something to do with it? isn't a 40 viscosity standard and good enough?
April 21st, 2004 02:02 PM #15
SAE 40 is good in the protection side... what being looked into here as a possibility is that its a monograde with a single viscousity property. Thus the engine oil will cause the same resistance all thoughout the temp levels and engine performance cycle (cold operating temp, low RPM traffic conditions, etc). It was pointed out before that if you look at the oils that give "fuel saving" properties like Caltex Havoline Energy, they run on a thinner visousity which gives lesser resistance at cold and hot operating temps.
This is just one facet of the discussion.
Tsikot Member Rank 3
- Dec 2002
- 636
May 19th, 2004 09:14 AM #16The local Sae40 oils have lower Api ratings(CD,CF) while the multigrades 15w40 usually start at ApiCF4 to CG4. This means better additives which keeps the oil from breaking down sooner. Also better detergents to keep engine clean.
Have fuel filter changed if it's done about 20k km.
got to check one out at sm san fernando today. rear visibility is very poor :twak2: and as typical...
2020 Kia Sonet
