Results 11 to 18 of 18
January 30th, 2006 02:11 PM #11
petron xtra unleaded..ok 'to..93+ RON..I''ve seen a little significance on fuel savings on my 7g galantSS.. well of course with good driving habits + tuned condition of the car,..so to speak!
January 30th, 2006 02:15 PM #12
There's no point of using anything other than the cheapest fuel for a dinky 1.3 engine... unless it's a wankel or something...
Don't forget, it's a 1.3Li engines, other than fuel economy, there's no reason why manufacturers would even "tune" it to use expensive fuel. - Kinda defeats the purpose if high octane is required...
The off-the-pants "gain" most people feel with higher octane simply means that the car's timing is advanced a little to accomodate it.
January 31st, 2006 11:40 AM #13
lowest octane rating gasoline that doesn't cause knocking in your engine or better yet check your manual. i drive a bmw325 and a yamaha r1 and use 93 octane gasoline in both of these vehicles and wala naman problema... kasi yun ang nakalagay sa manual. actually recommended nila eh 95ron pero pwede naman daw as low as 89 kaya i use 93 ron na lang.
January 31st, 2006 12:07 PM #14
boyscout is right, as long as it doesn't cause your engine to knock, there is no point in paying extra for higher octane fuels. if you really wanna make sure, do check your manual
Toyota is my choice
- Aug 2005
- 2,063
- Jan 2006
- 3
February 3rd, 2006 12:17 PM #16Salamat po sa inyong mga impormasyon at marami akong natutunan. hopefully, makatipid ako at mapatagal ang sasakyan. anyway po sa manual kc nakalagay engine disp ay 1,339/SOHC at recommended fuel niya ay unleaded minimum of 91 RON lang. Di ko lang alam kung may 91 ron dito or yun ba ang katumbas ng 93 dito sa pinas e.g sa super unleaded its 95 octane nakasulat sa gas station.
February 3rd, 2006 08:02 PM #17
use petron xtra unleaded. it's better than shell unleaded based on my experience. my engine knocks when i use shell unleaded but when i switched to petron, nawala na.
Toyota is my choice
- Aug 2005
- 2,063
Nag try sa suking Shell. 300, Mits oil filter sa Banawe 1700+, Shell hx7 350, change oil 750,...
All new Mitsubishi Expander MPV!
