Common causes would be missing or erroneous tire speed sensor readings from one or more wheel hubs, but checking for DTCs would be a good start. If the issue is local to the traction control system (TCS), like problems with the speed sensors, the codes would likely start with a Cxxxx (Chassis). If the TCS is the problem, you might get a Pxxxx (Powertrain) code, if the ECM is not getting a signal from the TCS.
On the majority of vehicles, the TCS is integrated into the ABS module.
Apparently, the main cause is a leaky brake caliper. Ubos Ang brake fluid Ang reason kung bakit umilaw iyong vsa icon.
The problem is Hindi kaya Nung caliper kit na available sa market kaya buong assembly Ang need palitan.
Quote Originally Posted by carxynogen View Post
Anong car po yan? Baka sign lang na need replace new battery yung car.
Naisip ko din iyong low batt bro Kaso Ang culprit brake caliper na Pala. Malakas Ang leak sa brake fluid kaya naubos iyong brake fluid.
Honda civic fd 2 Pala iyong kotse.
