Results 41 to 50 of 53
November 8th, 2012 06:50 PM #41
Chief, forget the current D-max. It's been the same pickup since its release in 2007.
2 to 3 years ago it was still quite reasonable to buy one brand-new, but definitely NOT now - You'd be better off with a clunker 2nd-hand or used cheap D-max, i'm afraid, if your family still wants any of them just to take you from point A to B.
It's a different case with me or for any D-max owners who bought them say between years 2007 to 2009 - i'm keeping mine kasi modelong hinDMAXsiado pa rin hanggang ngayon eh haha! :hysterical:
Your case is different though, and you deserve way better. You'd be wasting money, A LOT, if you get the current one now brand-new and then the all-new RT-50 is issued before 2014 next year.
See Top Gear Phils website - look for anything about Isuzu as there is an official statement there by Isuzu Philippines that works are underway to bring the all-new model to Philippines.
Good luck.
Cheers!
- Jan 2009
- 60
November 8th, 2012 08:27 PM #42
- Jun 2012
- 4,448
November 8th, 2012 08:35 PM #43
- Jan 2009
- 60
November 8th, 2012 09:44 PM #44
- Jun 2009
- 222
November 8th, 2012 09:53 PM #45DOE mentioned they covered 333 kilometers so if we convert the mileage into total fuel consumption the result is as follows.
(Tangalin na lang natin ang Croswind and 3.2 Monty sa list... then let me arrange from lowest consumed daw... para masaya... heheh)
16.19 Liters Isuzu D-max 2.5 LT (81-hp 4JA1-L) - 20.57 km per litre
17.13 Liters Isuzu Alterra 3.0 Ddi-iTEQ (146-hp 4JJ1-TC) - 19.44 km per litre
17.42 Liters Toyota Hilux 2.5 D-4D (102-hp 2KD-FTV) - 19.12 km per litre
17.93 Liters Mitsubishi Strada 2.5 Di-D (136-hp 4D56) - 18.57 km per litre
18.09 Liters Toyota Innova 2.5 D-4D (102-hp 2KD-FTV) - 18.41 km per litre
19.52 Liters Nissan Navara 2.5 (144-hp YD25DDTi mid-power) - 17.06 km per litre
DOE did not mentioned if they measured the fuel temperature inside the tank.
I hope they did dahil kung hindi, bahala na kayo magsabi kung tama ang test nila.
Merong fuel return pipe ang mga fuel system. Kaya meron nyan dahil of course meron bumabalik sa tank.
More pressure - more volume of return.
More pressure - the hotter is the temperature of returned fuel
Kung sakal ang tuning sa injector yet the system uses a generic pump, mas marami ang volume ng returned fuel and mas hotter ang fuel tank.
In every 14 degree Celsius increase in temperature of fuel, meron about 1% increase in volume due to thermal expansion.
We can never be sure how much is the temperature rise in the fuel tank because DOE did not include it in their report.
My estimated range is about 1 to 4% increase in volume.
Wala pang 20 liters ang na consumed ng mga vehicle enumerated di ba? Kung 70Liters ang tank capacity nila, meron remaining na more or less 50 Liters
1 to 4% of 50 Liters is equivalent to 0.5 to 2 Liters increase in volume due to thermal expansion.
It will look like you consumed less fuel when you fill the tank immediately after a long trip but try to top-up again early in the morning when the fuel is at its lowest temperature. You may be surprised.
Kung you are in your highschool years mapagbintangan ka pa at masabihan na "Saan mo na naman inikot ang sasakyan? Bakit bawas ang laman ng tanke eh full-tank daw yan bago mag grahe? (Based on experience to noon meron pa kami fleet of PUJs na graduated kawayan ang level gauge.... hahaha). Glad I can explain it now but no more PUJs... heheh
November 8th, 2012 10:42 PM #46
Kaya sa iyo lang ako chief eh!
Unfortunately, everything that is liquid is measured in volume, rather than by mass (except perhaps when in comes to Mercury); while the mass or weight stays constant the volume changes in respect to temperature and pressure.
Chief, does a diesel engine's frugality in fuel has something to do as well with the pressure from the rail, aside from the pressure in the tank? Does higher pressure in the rail gives better fuel mileage or no? - although diesel EFi tuning kits like the Racechip Pro, which actually raises up the rail pressure from stock, has quite a positive impact on fuel efficiency....
Cheers!
- Jun 2009
- 222
November 8th, 2012 11:31 PM #47Yeah you are right that is on the retail side.
But if you purchase in bulk, the unit price is usually per mass. Or draft (in case of lighterage or MS)
Due to the further development and improvement of fuel system and controllers (ECU), engine frugality is basically a choice. Its an OEM prerogative but mostly dictated by sales people after their "market needs/wants" study.
Isa pa hindi nakakasabay ang transmission system development especially low-cost, high torque, lightweight and high reliability sa development ng engine. Kaya meron bottleneck, most engine fitted with modern system are derated.
If such high power setting engine - modern high torque tranny are combined, the price will be too high. So those are only fitted in premium models intended for market that can afford and willing to shoulder the present and subsequent cost.
November 8th, 2012 11:42 PM #48
The latest Renault-Nissan developed Nissan Navara 3.0 V6 ST-X (235 hp, 550 Nm of torque ), with out-the-door or drive-away price of A$64,000 for a base-model could qualify in the sub- to premium pickup range then, if there is such labeling for a pickup hehe....
Hay, kailan kaya ako magkaka-BMW X5 diesel haha!
Sige na nga, Crosswind nalang :hysterical:
Cheers!
- Nov 2012
- 15
November 9th, 2012 02:16 AM #49Nga pala sir just found out na walang kasamang bed liner yung hilux when you get it, regardless kung anong variant according to the SA. For those in the north, is this true? If yes, bakit hindi malagyan ng toyota ng bedliner eh if they get everything in bulk magiging minimal nalang yung price nun. To think na the bed liner comes standard in a lot of pick ups nowadays.. Hays.
- Feb 2011
- 51
November 9th, 2012 08:54 AM #50^^ ang alam ko po, bibili ka sa kanila ng bedliner. ang pagkakatanda ko ay 15k ang price ng bedliner. meron din po sa carryboy, mas mura.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
