Results 11 to 16 of 16
February 4th, 2006 03:25 PM #11
When you're at certain speeds, most automatics (the Sentra's, included) select a gear based on how much gas pedal you're using. The problem is, if you're using medium pedal pressure, they'll sometimes think you want to cruise (so they stay in a higher gear) or think you want to accelerate (so they go to a lower gear). This is especially irritating if you want to overtake, you press on the pedal harder and the computer takes a second to realize that you actually want to overtake and then changes the gear.
With CVTs, that doesn't happen. Once you press the pedal, the revs go up, and the gears merely adjust to keep up.
February 4th, 2006 10:15 PM #12
Tama po si niky.
Gear hunting can be irritating for some drivers kasi. Pero hindi naman defect yun.
February 5th, 2006 11:52 PM #13
CVT is the best. You can choose between smooth cruising with absolutely no rough shifting (since there are no gears) and a bit sporty manual mode. The Lancer MX has 6 virtual ratios that offer some kick when accelerating, which is somehow enjoyable for some drivers.
February 10th, 2006 01:02 AM #14
thanks niky and otep for explaining gear hunting.
sa case ko naman kasi i'm considering the lancer gls. pero i can't find any review when i did a search.
- Jan 2006
- 13
February 10th, 2006 10:41 PM #15naka sentra 1.6 GS kmi, okey ang features, malakas ang A/C, pero medyo malakas sa gas and medyo sluggish.
February 10th, 2006 11:16 PM #16
based on looks,,lancer for me.
napapangitan talaga ako sa grasshopper-eye rear lights ng sentra.
plus you get CVT with the lancerLast edited by Kanut; February 10th, 2006 at 11:20 PM.
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
