Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
    Aug 2012
    Hello Everyone,
    Would you guys be able to point me to a Brand New popular Sedan available in our market that has the highest ground clearance?
    Thank you! :D
    What price range will you be interested with? A sedan is a car that has 4 doors and a trunk. Most sedans though are not welll endowed with ground clearance compared to MPVs, PPVs, CUVs, or large SUVs.
    Mirage g4 170mm all stock. With bigger tires it can go upto 185mm
    Aug 2012
    I am looking at a maximum budget of 1.1M. We already have a CUV. I am currently looking for either an MPV/AUV or a Sedan.
    High clearance is required, since the ramp for our garage is kinda steep. Not sure how to measure the minimum clearance I need for this.
    Please don't recommend Innova, as that is already a given.
    Altis might have 175mm ground clearance. Still needs verifying..
    Honda Brv has 200mm ground clearance and seats 6-7.
    Mar 2004
    Why a sedan in the first place if you need the ground clearance?
    Short front overhang is key for worry free ramp entry. Compare em. The R53 MINIs can get up almost any ramp even w/ really low ground clearance.
    For 1.1M, you have a lot of choices. You just have to check each one of them at the dealerships and test drive each one of them. If I do have 1.1M, I'd get the Focus Ecoboost Titanium (sedan), turbo power is much more fun to drive.
    Quote Originally Posted by slapz View Post
    approach and depart ramp clearance? a minicar with their wheels pushed to the corners will do the trick! if the british mini is too expensive for your needs, lookit the wigo, mirage hatch or celerio...
    cheep!
    or, you can opt for a different approach to your problem.
    tambakan nyo nang kaunti yung mababaw na parte. lagyan ng tubo, if drainage is an issue.
Sedan with the Highest Minimum Ground Clearance
