Results 1 to 10 of 34
- Aug 2014
- 391
June 23rd, 2018 11:53 PM #1Hi,
Need help on which to choose. Side by side can be seen on this link.
Compare Nissan Navara 4x4 EL MT vs Mitsubishi Strada 2.5 GL 4x4 MT vs Ford Ranger 2.2 XLS 4x4 MT | AutoDeal
But in case there are owners of this kind of PU, please share your input. Mitsu is the cheapest 4x4 based on the link of autodeal, and some bank calculator, (excluding PMS) but seems this variant still using the 4d56 engine.
PMS - which is cheaper on those PU?
Really hard to find reviews on this kind of variant, in case you have some link, please share.
Thanks in advance.
June 24th, 2018 01:10 AM #2
Since 4x4 Pickup ang hanap, kung nasa field naman ang work at laging dumadaan sa mga gravel/sand/rock, panalo yan..
Pero kung mostly urban driving, stick to 4x2...
Karamihan ng mga Pick-up, Part time 4WD... di ko sure kung pwedeng gamitin features lalo kung wet road condition lalo kung sa highway driving... (shift-on-fly)
kasi rekta ang 4WD agad.. (sprocket).. matindi ang grip sa gulong, pero hindi pwede gamitin lalo kung paved ang kalsada at dry condition.
binding ang mangyayari at matinding stress sa transfer-case..
June 24th, 2018 04:46 AM #3
- Apr 2010
- 742
June 24th, 2018 06:47 AM #4We prefer the Strada but called dealers as far as Laoag and Naga and kahit anong mid to high end variant wala. Per one agent, baha na daw yung mga units na dumating dito from Thailand(?). Notice na almost wala ka ring makikitang new units ngayon on the streets. Center diff is great but IIRC on AT variants lang yun.
Settled for the Navara which was our second choice, 4x2 nga lang. Hindi naman hardcore yung destinations namin and you can invest in tires and chains if needed be sa mga situations na ganun, worse you can always do a U-turn.
Tested a Ranger pero Wildtrak nga lang, didn't liked the electronic steering and the console, also daming horror stories sa Ford casas and costly pa.
June 24th, 2018 07:16 AM #5
You can shift on the fly to 4H mode in a Mitsubishi Strada up to 100 kph ... but in 4H mode you can speed up to more than 100 kph ... also the 4WD system in the Mitsubishi Strada is not supposed to be used on cemented or asphalt roads ... only on unpaved roads or maybe wet paved roads ...
- Aug 2014
- 391
June 24th, 2018 09:11 AM #6
- Aug 2014
- 391
June 24th, 2018 09:18 AM #7I actually plan to have 4x4 so i can go to places na limited ang 4x2, minsan kasi may mga lugar na si multicab na 4x4 dumadaan pero yung mga bagong 4x2 takot. Though mostly naman is cemented ang dadaanan but at least incase needed magagamit. If i can proceed with strada any feedback for common issues, for navarra and ford owners naman nung mentioned specs baka maka feedback din. Thanks.
Sent from my SM-A520F using Tapatalk
- Apr 2010
- 742
June 24th, 2018 09:31 AM #8i believe hydraulic pa rin ang steering even for the VL 4x4 variant. Ranger lang ata ang may EPS, not so sure.
early releases of the Navara ay may reports na lagatok sa steering which was replaced by casa for free, wala kaming na experience na ganun. fixed na daw on succeeding models with a new part. ours is a 2018 Q1 Calibre A/T 4x2, before the facelift.
no issues pa naman, i carry with it my enduro motorcycle. it's quite boringalthough it is fast in picking up speed kahit 160hp/403nm torque lang
driven the Strada, Ranger, DMax, Hilux.
- Apr 2010
- 742
June 24th, 2018 09:43 AM #9baka takot lang magasgasan
yung mga pinupuntahan mo pa rin ang magdecide kung kailangan mo talaga ng 4x4. around 200k+ kasi difference ng 4x4 (on A/T models at least) kaya di namin majustify.
even when we had the Terrano dati we seldom use its 4x4 function, kaya naman pala with the right tires. pero as usual, it is better to have it when you need it...
youtube.com/watch?v=m02k_g3E0xw
- Aug 2014
- 391
June 24th, 2018 10:20 AM #10
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
