which one if more fuel efficient honda jazz 2009 or toyota vios 2009? i'll be buying a new car,help plsssss![]()
hindi po ba masmalakas yung bagong vios kc mabigat sya? ano po ba ang difference ng gross weight sa curb weight? pareho lang yun dba? kc parang sabi sa net nasa 1400+yung gross weight ng vios na bago
These are the listed curb weight for the cars:
Vios 1.3L = 1,075 kg
Vios 1.5L = 1,110 kg
Jazz 1.3L = 1,050 kg
Jazz 1.5L = 1,110 kg
Gross weight would the car manufacturer's estimate how much people and cargo would weigh.
Vios 1.3L = 1,485 kg (gross)
Vios 1.5L = 1,520 kg (gross)
Jazz 1.3L = unlisted
Jazz 1.5L = unlisted
Perhaps we should rephase the quesions, so as to avoid 'it depends' answer
Under similar driving conditions/styles, both stock setups, same fuel, which one if more fuel efficient honda jazz 2009 or toyota vios 2009?
Unless you get the exact same driver in the exact same conditions... we'll never know. Both cars can do 15s, and both can do 20 and over if driven right...
The Toyota engine has better low-end torque, the Honda better high-end power... for some, the Toyota is perceived to be more economical, because they can press less on the gas for the same amount of power, where they are tempted to really bury the gas on the Honda, but if you drive them the same way, fuel economy is quite similar.
It would be very similar. All you have to do is pick the car you really like.
Can't go wrong with both choices either.
Nope. At best, they're the same in terms of performance... but the Jazz is probably slightly faster.
Extra torque at initial tip-in gets you off from a stop faster, but what determines how fast your car can accelerate is horsepower throughout the range.
As an example, our Crosswind responds more immediately when you step on the pedal from a stop than the CR-V. But there's no way in hell that you'd ever consider a Crosswind as "fast"......the moment you're over 5 km/h, the CR-V leaves it eating dust.
When I say the Toyota engine has extra torque down low, that just means it's a bit easier to drive at low speeds... but at higher speeds, the Honda engine is better.
ah ok, yun pala yun, hirap kc mamili dahil din sa itsura yung vios parang semi luxury yung jazz parang pang teenager, pero jazz na lang cguro kukunin ko since masmalaki ang space nya, ty po sa inyo
