Results 11 to 20 of 26
August 15th, 2014 10:23 PM #11
Thank you mga sirs, really appreciate your inputs. Our innova really served us well, except for that d4d issues at that time (2005-2007 models) which toyota eventually addressed by replacing its (or they installed?) a suction control valve, i have no regrets, till now, it runs really well and super tipid sa gas that is why i have second thoughts about its replacement.
I can only afford kasi for its possible replacement the base model monty which is non- vgt, compared to innova, say the mid trimmed G or even the V, how will it fare in terms of engine power vis a vis the turbo lag of a non vgt monty? Thanks guys..
August 15th, 2014 10:48 PM #12
Sir hugobo
Sobrang bawing-bawi na po yung innova nyo in terms of usage, retain nyo po yung current vehicle nyo at gamitin for workhorse, then bili ulit ng "full-upgrade" since ang target nyo po ay montero(or other different model variant na gusto nyo) wag po tipirin...
Top-end and High end po ang category nyo po Sir...hehehe
- 52,697
August 15th, 2014 10:58 PM #13kung comfort at easy ingeress and egress ng passenger innova and kung sasakay parents or grandparents mo innova na para di hirap sumakay[/QUOTE]
i held on to my sedan for this, the mobility-impaired... even if it guzzles gas..
kung puede lang i-lower ang innova and still drive good look good...
- 52,697
- 81
August 16th, 2014 01:04 AM #15test drive the montero sport glx that you want and compare it to your current innova.
- Apr 2007
- 487
August 16th, 2014 03:57 PM #16Are there any mid-sized SUV (MS, Fortuner, Alterra, etc) that can match the Innova's cabin space and ride comfort?
- Sep 2010
- 81
August 17th, 2014 09:19 AM #19
The fortuner has identical cabin layout as the innova, even the floormats are the same.However, the floor of of fortuner is higher, contributing to less leg space as well as less headroom. The MS is like a raised sedan, with very low sitting posture, hence the difficult ingress/egress. The alterra is indeed roomy but very long, better check your garage/ parking space.Tried to sit on the third row of trailblazer -- claustrophobia--- with non sliding 2nd row.
- Oct 2013
- 310
August 19th, 2014 01:45 AM #20Consider the Crosswind also. Same layout as the Innova but better ground clearance.
Posted via Tsikot Mobile App
Suzuki JIMNY [merged threads]
