Results 31 to 40 of 43
- Mar 2007
- 73
May 29th, 2007 09:50 PM #31
- Nov 2006
- 316
- Mar 2007
- 73
May 29th, 2007 10:04 PM #33
- Nov 2006
- 316
June 1st, 2007 08:09 PM #3415" rin pala sa EX version. sa iba bansa kasi 16" o 17" ang gamit sa EX. para mas mataas kundi yun look nya.
June 3rd, 2007 03:34 PM #35
one of the things that i'm concern of about carens is the ground clearance, it's a lil low compare to innova. i wonder if i'll change the rims from 15" to 16 or 17" i don't know if it will make any diffrence and it will cost a fortune. but definitely i love the ride, the looks. the smoothness? well, i had only driven isuzu hi-lander & fuego, there's no comparison to it! i'm not sure of its fuel efficiency yet. i got the lx m/t crdi model just to save a li'l on fuel comsumption compare to the a/t. hope to hear some inputs from you guys, thanks...
- Nov 2006
- 316
June 3rd, 2007 09:57 PM #36ground clerance is nothing for me. all my concren is the durability of Kia badge. I saw some Sedan have lower there body and have no problem on the road. but the durability is the major concern of all the car buyer today.
June 3rd, 2007 10:46 PM #37
True, durability is a big unknown for modern Kias. While some Koreans show exceptional reliability in their first three years, some... don't.
But everybody's got to start somewhere, right? From comparisons with old Korean cars, the quality is really skyrocketing. Let's hope that translates to higher reliability (knock on wood), too.
June 4th, 2007 09:00 AM #38
yeah you're right, the durability of the car itself is the most important thing to consider. that's the first thing that rangs in mind, but my common sense dicatates that they don't just build cars lets say good for only 5 years. no offense to toyota d4-d, they have their fair share too. as long as you used it properly i think everything will just be fine (5yrs ++) and proper maintenance too.hey, one thing also i noticed, the temp is li'l lower than half i wonder if thats really the normal operating temp. or better yet i'll have it remove (thermostat)... for better H2O circulation. that's what i did w/ my fuego & hi-lander, it really works! but i'll consult kia first before anything else. have a nice day!
June 4th, 2007 01:14 PM #39
I'd suggest not to. Running at low temperatures is actually bad for your valve-train, as the casa-used oil (usually a heavier grade, like 15w40...) doesn't get up to the temperatures where it achieves good lubricity.
Leave the thermostat in. If temperature is a problem, add some Redline Water Wetter and/or an oil cooler to your vehicle.
June 4th, 2007 01:27 PM #40
hi, i dunno about oil cooler, can you please give me an example? thanx...
high idle RPM at engine start
