Results 41 to 50 of 83
February 11th, 2020 12:13 AM #41
So that''s Fortuner with an 18" and Innova with a 16" tama po ba?
Using the numbers you mentioned, putting 17" to Innova would result to around 193mm na sinasabi ng mga indian reviews about Crysta ground clearance.
Pwede na kaya yun sa soft na offroad?
Sent from my SM-A505GN using Tapatalk
February 11th, 2020 12:14 AM #42
February 11th, 2020 12:28 AM #43
February 11th, 2020 12:30 AM #44
- May 2016
- 546
February 11th, 2020 12:31 AM #45Not exactly since 17 uses lower profile tires to compensate for the bigger wheel size. In effect, it maintains similar tire circumference.
Input niyo yung stock sizes ng Innova, 205/65R16 at 215/55R17 sa tiresize.com, lalabas dun almost same circumference. Same speedo reading.
Kailangan mas mataas overall diameter para tumaas ang clearance, so kailangan laruin yung combination ng wheel at tire.
- May 2016
- 546
February 11th, 2020 12:36 AM #46
- Apr 2008
- 6,235
February 11th, 2020 12:50 AM #47If your idea of soft off road is uneven, unpaved road surface with a few rocks here and there then yes, a 193mm ground clearance should do fine. Some crossovers make do with less.
Our 2010 Carnival has only 167mm with the stock 225/70R16 tires. The tire size calculator says that 245/70R16 has a height difference of 28mm, divided by half for the radius equals 14mm, now giving me 181mm (tama ba ang calculation? [emoji28]). So far no scrapes naman when it was driven to such road surface in Baguio.
Oh, and our Japan surplus Toyota Granvia has a 195mm ground clearance. Same place in Baguio, performed like a champ!
Sent from my SM-G965N using TapatalkLast edited by GTi; February 11th, 2020 at 12:53 AM.
February 11th, 2020 12:54 AM #48
Play w/ wheel well & suspension rub thresholds & wheel offsets, esp out front where you factor turning clearances in. Tires that yield above stock outer diameter can throw the speedo off... something that can be consciously noted & tolerated if increased ground clearance is the priority.
February 11th, 2020 12:57 AM #49
- 54,205
February 11th, 2020 12:59 AM #50madalas sumabit my innova's underside hatak rings, sa workplace parking's tire-stops.
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
Mitsubishi Philippines
