Page 4 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 83
    Jun 2009
    #31
    If limited sa 2 choices and considered mo yung Innova G?
    Then get the Innova!
    I’m still using our 13 year old gas fed Innova G [emoji23]
    Ayoko damihan choices mas nakaka-lito hehehe
    Here at work we use 4x4 only and we used to have other brands like Ford and Mitsubishi.
    Now only Toyota remains.
    The old Land Cruiser Safari is still working nearly 300k miles while the other brands already retired 8 years ago.
    I can always see old model hilux and corollas na fully loaded (the usual scene you see on African movies) plying the unpaved roads of Africa with ease hence I love Toyota hehehe.
    Sent from my SM-A505GN using Tapatalk
    Apr 2008
    #32
    Quote Originally Posted by rufoh View Post
    Sana sa 2021 gawing 17".
    The bigger the rim the more expensive the tire! [emoji23] Sa 2010 Carnival namin, I replaced the stock 225/70R16 with 245/70R16. Natuwa ako at hindi na sumasayad ang nguso niya sa mga matatarik na rampa. [emoji28]
    Hindi mo ba kailangan ng 4x4? The Hilux 2.4E 4x4 is a good deal, IMHO.
    Sent from my SM-G965N using Tapatalk
    Jun 2009
    #33
    Mga twice a year lang po aahon sa Mt. Banahaw, the rest city driving na and family car hence Innova or Rush.
    Ayoko po pick-up ganyan gamit namin dito work sa Africa kaya alam ko yung tagtag hehehe and nakukulangan ako sa space sa loob lalo na nilagyan na gamit mga bata.
    Apr 2008
    #34
    Mga ganon kataas ang gawan mo. At least pantay na siguro sa Fortuner ang taas niyan.
    Jun 2009
    #35
    Quote Originally Posted by GTi View Post
    Oks na siguro yan sir. Actually maski lower nga about 8" pwede na yun.
    Ano po ba ground clearance ng current Innova 2020, is it 190mm?
    Apr 2008
    #36
    Toyota PH's spec sheet doesn't say, but most unofficial online sources agree on 176mm.
    Jun 2009
    #37
    193 sa Crysta in India. Sa ibang website may nakita pa ako 167.
    If it is indeed 176mm then it is around 1" lower than Avanza (200mm).
    Adding 2" (176 + 50.8 = 226.8mm) will indeed bring it higher than 220mm of Fortuner
    Jun 2009
    #38
    Don't join this club, doc....[emoji38]
    A cousin did not listen nor heed, he's now the staunchest Don't Rush advocate.[emoji13]
    Buti nagtanong muna ako. If I may, ano po mga comments niya about Rush?
    #39
    It makes the Fortuner dwarfed
    Compared to 2nd gen Fort:
    yak!
    it looks as as bad as a lowered advie!
    May 2016
    #40
    Base it on the Fortuner with 225mm, less the difference in tire radius, around 50mm sabi ng tire calculator, and you get 175mm give or take. Both use the same platform and underchassis, so pwede iassume.
    These numbers don't mean much. Mas tiwala ako sa Innova with a lower min clearance than a crossover na mas mataas.
Innova G or Rush G ?
