Results 1 to 10 of 12
- Feb 2006
- 108
August 6th, 2014 09:12 AM #1alin po kaya ang mas okey na van sa 2 sasakyan in terms of fc, parts and maintenance
Certified MB Addict
- Apr 2007
- 2,284
August 6th, 2014 09:18 AM #2Wala, you're better off buying another vehicle than those 2, the Vanette had such a bad rep during its heydey, the Serena is converted, something I wouldn't touch with a 10 foot pole
- Feb 2006
- 108
August 6th, 2014 09:30 AM #3thanks po sir ron sa mabilis na reply ganun po ba, ito pong 2 na van ang medyo kaya ng budget tapos yun serena diesel kaya medyo lamang na sa fc
Certified MB Addict
- Apr 2007
- 2,284
August 6th, 2014 11:21 AM #4How much is your budget if you don't mind me asking. Between the 2, mas bibili pa ako ng Tamaraw FX basta maayos ang kundisyon.
- Feb 2006
- 108
August 6th, 2014 11:50 AM #5parang okey po un serena hindi naman kalakihan na van diesel yun nga lang po imported
- Apr 2008
- 6,235
August 6th, 2014 01:45 PM #6I'm not touching the Vanette. The Serena may be worth considering if you're somehow 101% sure of it's roadworthiness and the cleanliness of it's papers.
But then if possible, I suggest you look elsewhere.
Sent from my GT-I9100 using Tapatalk 2
- Feb 2006
- 108
August 6th, 2014 04:54 PM #8
For the Vanette,- I own a 1998 model,- FC is 6Km/L city and about 7-7.5Km/L hiway - driving style ko iyan...
Parts and maintenance,- the only parts I replaced are :
1 front signal light,
AC compressor 2x, had one of the condensers moved underneath the front passenger
Alternator OEM broke down 5 years ago and because of my oversight, as I did not notice that the power steering fluid was leaking on the OEM alternator, and I had a couple of alternator changes after that, so every 2.5 years,- P3,500
power steering hose (low pressure side)- 5 years ago
Belts - it has 3 - 1 set-change only six years ago
Idler pulley - the OEM became noisy only a couple of months earlier
Replaced the OEM lower portion of the cooling hose five years ago
Had the OEM radiator overhauled 2 years ago
Replaced the OEM radiator cap 5 years ago
Just the regular oil change every 5KKm or one year, whichever comes first; sparks, condenser, contact point..
Still, a lot of OEM - all of the lights (except for the 1 front signal), coil, distributor, high tension wires et al
No issue driving it,- and it's a real tank for me... Now, if you are looking for better FC,- then, do not buy any of the gas-fed vans... The argument here vs a car is that it can do 6Km/L but can ride 8-10 persons, which can fit in 2 cars doing only 8Km/L each - so effectively 4Km/L - your choice!
“Familiarity breeds awe”
23.9K:thud:Last edited by CVT; August 6th, 2014 at 05:00 PM.
- Jul 2003
- 573
August 6th, 2014 11:09 PM #9what is the specs of the Serena, other than import and diesel? country of origin? Turbo? etc...
- Apr 2008
- 6,235
August 6th, 2014 11:34 PM #10If you're open to surplus cars, might I suggest you consider Korea surplus instead. Being originally LHD, that's one less major worry off the list.
How much is the budget, by the way?
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
