Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 56
    Oct 2005
    #21
    Torque.
    My Accent makes 110hp and 235NM of torque. It flies.
    Compared to my old Vios 1.5L 107hp and 145NM. ;)
    Sep 2013
    #22
    Quote Originally Posted by jhnkvn View Post
    Depends on the RPM graph.
    "VTEC kicked in yooooooo!!"
    Curious lang sir, san galing yang quote? been seeing that here in H-car bashing threads.
    i did see an EK / EG (forgot if hatch or sedan, too young then) with decals at the back: "When VTEC kicks in, i'm gone...."
    probably dead now.
    #23
    Quote Originally Posted by nori View Post
    probably dead now.
    Search mo sa YouTube, theres a video of a guy who was so awestruck with the Jekyll-and-Hyde transformation of his friend's Civic after it enter VTEC range.
    Apr 2012
    #24
    for racing = more HP
    for towing = more Torque
    Oct 2013
    #25
    Torque ako kasi can't afford hp! Hahaha.. sa needs ko torque mas kailangan..
    Sent from my LG-D802 using Tsikot Forums Mobile App mobile app
    Beep Beep! School Bus! Beep Beep! School Bus!
    #26
    Toyota - T for Torque
    Honda - H for Horspepower
    mas kailangan ang torque lalo na dito sa atin na kailangan mag-overtake. vtec is great pero matagal pa bago sumipa (at higher rpm range meaning you'll consume more fuel) and that delay in time for overtaking is a matter of life & death kaya mainam na as much as possible mababa ang peak torque like with modern day crdi, kapag tinapakan mo bigay agad ng power when you need it.
    Sep 2012
    #27
    Quote Originally Posted by 170kphlang View Post
    What I do when I overtake, I shift gear 1 down then gear 1 up when I feel that I got the right rpm, I hear the VTEC kicks in
    BTT: basically it's the Torque
    #28
    The high-revving nature of the Hondas don't necessarily mean malakas sa gas.
    The R18A on the Civic actually has decent mileage. Also, even without having to use the upper rpms, kaya namang magovertake. I rarely found myself needing to go past 3000 rpm with an FD. Sa bagal magdrive ng mga tao, di naman kailangang flat out para makaovertake.
    Sep 2013
    #29
    kaya pala hirap si CIVIC ek ko sa bundok
    mababa pala ang torque..
    how about trailblazer vs. fortuner?
    balita ko mataas daw HP ng trailblazer
    "It's the driver" - Honduh fanboy.
    #retzing
    #31
    torque sa akin ... aanhin ko ang hp sa city driving?
    accdg to my OBD2 scanner, my diesel suv use only 25 hp while cruising 100 kph ... it doesn't really take much hp to keep a car in motion, but having more torque will make moving the car easier
    #32
    There is no difference between torque and horsepower.
    Well, there is a difference. You can have a million foot pounds of torque and have a car that's as slow as molasses. But if you have a million horsepower, as long as your gearing fits the motor, you will be very, very quick.
    This is because torque is twist, but without a time component, you don't know if that twist is applied in one second or one minute. Only adding a time component will tell you how much work that torque will do within a given timeframe.
    And what do you call torque applied over time? Horsepower.
    In other words, a Santa Fe 2.2 is not incredibly fast because it makes 436 Nm of torque at 2,500 rpm. It's incredibly fast because it makes 153 horsepower at just 2,500 rpm, and averages between 150-190 hp from 2,500 rpm to 3,800 rpm.
    Peak torque and peak horsepower figures are misleading and mostly meaningless. To gain a better idea of how quick a car can be, you need to know what the average horsepower and gearing are.
    And while peak acceleration in each gear occurs at torque peak, peak horsepower still matters, because that's where peak acceleration occurs when you're choosing between different gears, like so:
    #33
    yup gaya ng namention ng isang post dito, yung mga civics ng 90's-early 2000 ang nagsusuffer sa low end power but yung mga fd ay di na gaano
    Dec 2012
    #34
    Read this explanation somewhere: hp is like a sprinter--it gets you there faster but slows down with more load. More torque means it can move at the same speed with heavier load but it's not necessarily fast.
    My interpretation: You need more hp if you like driving fast with less load, and more torque if your car is usually at full load but you don't need to drive fast. More hp = mas mabilis. More torque = mas malakas ang hatak.
    #35
    Mga sir makikisawsaw na din po.
    Para mas simple ibukod natin ung engine alone hanggang sa flywheel wag natin sama iba component engine muna.
    Hp and torque are directly proportional to each other. Parang magkakambal po oyang dalawa na yan.
    Nagvavary lang kasi different engine perform differently.
    For example honda 6000rpm max power out put ibig sabihin yan ang max torque at hp niya.
    Nagiging complikado pagnasalpakan na ng transmission dahil sa gear ratio.
    So technically bigger engine can produce bigger hp and relatively higher torque.
    Nagkakatalo lang sa configuration ng gears sa transmission and/or gear box.
    Hope this helps.
    By the way on a mathematical standpoint hp is determined by the torque multiplied by the rpm - i hope i recall it correctly from my thermodynamics class.
    About gear ratio, mas maliit po ang gear mas mababa po ang torque. Kaya ung iba feeling nila mahina humatak ang vtec (stock lang ha walang iba confi) kasi maliit gear eatio niya at mas makakaproduce ito ng speed.
    Parang bisekleta lang sir at constant rpm bigger sprocket and main plate combi is lighter on your feet because it has bigger torque but speed will suffer kahit tulinan mo padyak mo hanggang dun na lang iyun. Pagniliitan mo naman ung sprocket tutulin ka pero mabibigatan ka kasi maliit ung torque na napoporduce ng sprocket naniyun kaya yo u need to exert more effort.
    Hope this helps mga sir.
    Sent from my GT-I9300 using Tsikot Forums Mobile App mobile app
    Oct 2011
    #36
    Hindi ba comparable sa gasoline and diesel engine? If you need more Hp then sa gasoline ka but if you need torque sa diesel engine naman.
    Sent from my iPhone using Tsikot Car Forums
    #37
    Mas maganda po paliwanag ni sir niky kaysa sa akin, inelaborate ko lang in my own words.
    Diesel engine at same size produces more hp and of course torque kaya mo ramdam ang torque is that of the diesel having higher hp can pull up a load faster on a smaller gear ratio.
    Imho ang limitation ng diesel vis a vis gas engine is the rpm. Kasi diesel engine are compression ignition while gasoline is spark ignition. Kaya mas mataas rpm range ng gaso sa diesel dahil sa flwxibility nito in controlling intake exhaust and spark timing.
    Dec 2007
    #38
    Quote Originally Posted by brainmafia_310 View Post
    this is the equation most tuners used to predict wHP during dyno runs...
    HP = T x 4000
    7120
    Where:
    HP - horsepower
    T - torque, Nm (engine torque mapped in the ECU)
    4000 - RPM
    7120 - constant
    HP to be multiplied with 10-12% (FWD) and 15-20% (RWD) for loses in the drive train.
    #39
    5252 if you're talking foot pounds.
    And more precisely, 7121 for Nm.
    Drivetrain losses are nothing more than ballpark, nowadays. With some cars using ultra low-friction drivetrains, you can't assume anything. The Nissan GT-R boasts some 10-15% losses only versus something like 20-25% losses for STIs and Evos.
    And then you get to the problem of dynos calibrated to different standards, SAE (over)correction and etcetera.
    #40
    used to be a big deal back then, but engine tech has matured since and microchips and control systems have increased performance and fuel economy. our road going cars benefitted much from f1 and other track cars.
    now going full electric...
Horsepower vs Torque
