What is better, high ps but lower torque or low ps but higher torque?
A good balance between the two will be much better. The key though is at what RPM will the max power and torque will be reached.
torque.
kaya hindi ako bumibili ng honda. taas nga ng rated hp e nasa 7000 rpm naman. sa normal driving 1000-2000 rpm walang kalatoy-latoy. yung civic ng friend ko konting incline lang need pa paabutin ng 3000+ rpm para maka-akyat. sa humps lang nga e 3000 rpm na hahaha! baklitang kotse!
Maybe the older Civics, City, or Jazz but not the bigger Hondas. Not all Honda's are the same. My old Honda can be rev-happy if I floor the gas but I definitely have enough torque at 2000 rpm. The newer Hondas with the R-series and K-series engines are well-suited enough for the daily commute.
The 1.3L i-VTEC engines that Honda puts on the City and Jazz needs the extra pressure on the gas pedal to make it run at an acceptable cruise. Even the 1.5L still lacks the extra pull when needed at low rpm.
If you want the extra torque, go get yourself a bigger engine. There is no replacement for displacement, unless you go the turbo path.
Power HP = Torque (ft-lb) x RPM / 5252
from this formula alone, Power is dependent of Torque. Now, for example in order to get a 200 HP
If RPM = 6000, Torque = (200HP x 5252)/6000 = 175 ft-lb, it means it is with higher RPM to get that 200 HP
If RPM = 5000, Torque = (200HP x 5252)/5000 = 210 ft-lb, it means it is with lower RPM to get that 200 HP
high HP, low Torque; it means you need a high RPM, just imagine if you have very low torque so you need very high RPM
low HP, high Torque; it means a lower RPM which more fuel-efficient
Diesel = torque
gas = hp
Kung same engine displacement, alin matipid, diesel diba.![]()
Those paper specs are rarely indicative of real-world performance.
Case in point - Vios 1.3 vs City 1.3.
Vios: 85 hp * 6000 / 122 nm * 4400
City: 100 hp * 6000 / 128 nm * 4800
The City makes much more power and a little more peak torque (at a slightly higher rpm). Based on this, it's easy to say that the City will have better performance.
However, anyone who's driven both would say that the Vios feels much peppier in city driving, and even at highway driving (80-120 kph) it doesn't feel breathless. The City on the other hand, takes a lot of revving to get into the powerband. It likes to be shifted at at least 2500 rpm to feel alive.
Torque ako kasi can't afford hp! Hahaha.. sa needs ko torque mas kailangan..
Sent from my LG-D802 using Tsikot Forums Mobile App mobile app
Beep Beep! School Bus! Beep Beep! School Bus!
Toyota - T for Torque
Honda - H for Horspepower
mas kailangan ang torque lalo na dito sa atin na kailangan mag-overtake. vtec is great pero matagal pa bago sumipa (at higher rpm range meaning you'll consume more fuel) and that delay in time for overtaking is a matter of life & death kaya mainam na as much as possible mababa ang peak torque like with modern day crdi, kapag tinapakan mo bigay agad ng power when you need it.
