Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 56
    Nov 2013
    What is better, high ps but lower torque or low ps but higher torque?
    city driving you'd prefer more torque
    A good balance between the two will be much better. The key though is at what RPM will the max power and torque will be reached.
    torque.
    kaya hindi ako bumibili ng honda. taas nga ng rated hp e nasa 7000 rpm naman. sa normal driving 1000-2000 rpm walang kalatoy-latoy. yung civic ng friend ko konting incline lang need pa paabutin ng 3000+ rpm para maka-akyat. sa humps lang nga e 3000 rpm na hahaha! baklitang kotse!
    Feb 2012
    Torque
    Nov 2013
    If the torque is 190nm/4300rpm better than 187nm/3600?
    Sep 2012
    Power HP = Torque (ft-lb) x RPM / 5252
    from this formula alone, Power is dependent of Torque. Now, for example in order to get a 200 HP
    If RPM = 6000, Torque = (200HP x 5252)/6000 = 175 ft-lb, it means it is with higher RPM to get that 200 HP
    If RPM = 5000, Torque = (200HP x 5252)/5000 = 210 ft-lb, it means it is with lower RPM to get that 200 HP
    high HP, low Torque; it means you need a high RPM, just imagine if you have very low torque so you need very high RPM
    low HP, high Torque; it means a lower RPM which more fuel-efficient
    Quote Originally Posted by 20santafe14 View Post
    Higher torque in lower rpm is better. The older Focus TDCi really had good torque figures for a compact car, 320Nm at 2500rpm.
    Diesel = torque
    gas = hp
    Kung same engine displacement, alin matipid, diesel diba.
    torque.
    Maybe the older Civics, City, or Jazz but not the bigger Hondas. Not all Honda's are the same. My old Honda can be rev-happy if I floor the gas but I definitely have enough torque at 2000 rpm. The newer Hondas with the R-series and K-series engines are well-suited enough for the daily commute.
Horsepower vs Torque
