Page 1 of 4 1234 LastLast
Results 1 to 20 of 67
    Jun 2010
    Hi to all car enthusiasts!.,I'm planning to buy a 2nd. hand car next month but with a limited budget of only 150k. My 1st. choice is Honda City Type Z or the Exi model and my 2nd. choice is Toyota Glxi/Gli model, can someone pls. suggest which of the 2 car brands is better in terms of performance and maintenance??. Before I used to have a Honda City 96 Exi model and its performance and engine is excellent only that the maintenance is costly (replaced A/F sensor, oil leaks at the distribution cap and crankshaft oil seal), maybe due to the 160,000kms. it has already reached. Any suggestions is much appreciated'.,also is there anyone who is selling Honda type Z or Toyota Glxi?..
    Thanks....
    All old cars will need more repairs.
    Best you can do is to find one in good condition with relatively low mileage on the odometer.
    Personally I would choose the Corolla because of the car being more common so you can have more units to choose from and potentially cheaper to maintain.
    But for your budget, it would be hard or impossible to find a car that is less than ten years old.
    Jul 2010
    honda pa din
    Depends on the model. In this case, I'd choose the Toyota...
    May 2004
    Ako honda.. pero I doubt kung may makuha kang 150t na 2nd hand Honda na in good condition
    since nagkaron ka na ng city before, better to get toyota naman. both of them are good reliable cars pero age is always a factor. more than 10 years old na oto will give you problems unless you well know the history of the car (which i doubt that the seller will give you).
    personally, better looking yung city than the big body. reliability, both are very reliable basta you've done all the repairs needed. performance, gli is 1600 and the city is 1300 so i think corolla will give more power. at that budget, i suggest na ipon muna kahit mga 20k para safe if something breaks down.
    Jan 2009
    Toyota, lalo na sa luma (older than 10 years), mas madali mahanapan parts at madali pa service. Although ganuon din ang Honda pero medyo nga mas mahal parts nito. Mahusay kung may magbenta sayo ng kotse na alaga ng dating may ari kahit 10++ years old na. Rare cases ito but it does happen.
    Apr 2008
    Honda syempre... Toyota has never been able to truly beat Honda in their vehicles' performance. they just gain ground in affordability and reliability. Their vehicles were never truly exciting or exceptionally good in performance, just practical and soulless. Some people may like that, but not me. The 1st Gen. City is an excellent car. It has a powerful 16V EFI engines across the line, good FC figures and the facelifted Type-Z actually looks pretty good. If you can find one that fits your budget then it would be really great. If possible, stretch your budget a bit further and get a newer unit for lesser problems. As for Toyota, you can go a notch higher with the older but bigger and more powerful 1.6 AE101. Another good alternative is the '93-'97 "itlog" Mitsubishi Lancer 1.6GLXi which has the same performance figures as the Corolla GLi.
    Jun 2010
    cguro nga with my limited budget I would go for the corolla even though by heart I still prefer Honda...,many thanx to all..
    cheers...
    Apr 2008
    I see, pero OK lang yan! The Corolla GLi is still better than the 1st gen City EXi in terms of size, looks, and performance. Having DOHC 16V EFI, its got the best performance in the compact car class of its day until the EK Civic VTi came in in 1996, so its really quite decent. But if you really want a Honda, the '93-'95 Accord EXi is available for 100+k.
    Kung ako choice ko Toyota kung second hand at medyo me edad na bukod sa piyesa na available at mura pa.
    Sep 2010
    i'd choose honda if i got the budget... but performance wise, Toyota ain't that bad, you just keep looking for that car. like you i am also hunting for one choosing between Corolla GLi 93up and Jazz but i dont have the budget for jazz right now,...goodluck on finding your car
    Jan 2004
    i'd go for a toyota. availability and affordable parts.
    go for Toyota
    :car:
    Toyota Corolla.
    I have a 1996 Gli and it still works perfectly! It's very easy to maintain and I'm a girl! So you should have a breeze maintaining your Toyota then.
    Does Toyota have a GLXi? Isn't that a Lancer?
    Dec 2018
    Quote Originally Posted by ЩдŗҜ View Post
    cheers...
    Guys sorry to bother, i need your wisdom on this, i am looking for a secondhand car, my options are 1 2005 toyota vios 1.3 nz engine, and a 2008 honda city 1.3 i-dsi engine, both with the same price both 5 speed manual, both same mileage, i will like to know what is the best option, considering i live in cebu, when it comes to parts availability, and fuel efficiency, and what engine give less hassle to repair and last longer, please help me out with ur wisdom guys, thanks. i just want a reliable car to go from point A to point B, i don't care about been fast etc, i just want the most reliable car. thank you guys.
    Feb 2014
    Quote Originally Posted by sumomosan View Post
    Honda makes the best engines. I'm still holding on to my old 1.3 i-dsi. Very reliable. More spacious than vios. Fantastic versatility with the ULT seats
    Apr 2009
    The City will probably be nicer to be in, but since you want the most reliable one, I'm siding with the Vios for this one. No need to look further if you're after reliability (and easy parts and maintenance). The 2NZ-FE has quite the resume for reliability, powering the 1999 Toyota Echo all the way to the 2016 Vios. Toyota knows what its doing. It may be old tech, but it won't let you down.
    Aug 2012
    if you are not badge conscious and you are in Cebu. for me better to get a toyota, original parts are everywhere and cheap. madami din surplus or replacement OEM if you're on a tight budget.
    Honda parts are also plenty but most are 3rd party parts or surplus, and usually mas mahal kesa sa toyota. mas mapapamahal ka in rebuilding your second hand car if may mga problema.
    for sure may papaayos ka jan, makina, especially suspension parts, and some bearings sa pulley. (wag maniniwala sa tag ng mga seller na, sasakyan nalang....)
    good luck bro. what was the condition of the both cars you had surveyed. both sariwa pa?
    test-drive them both.
    get the one you are more comfortable in.
Honda or Toyota?..
